Author Topic: How do you pluck two strings at the same time when using a pick?  (Read 2894 times)
Violeiro
Psalm 3:5 I lie down and sleep; I wake again, because the LORD sustains me.
Re: How do you pluck two strings at the same time when using a pick?
« Reply #1 on: July 18, 2019, 08:52:08 AM »
I'm not sure how other people do it, but I hold the pick between my thumb and index finger, then use my middle finger to pluck another string.  Seems to work pretty well.
tedtan
« Reply #2 on: July 18, 2019, 10:30:44 AM »
I would do it the same way as DennisG describes, picking the lowest pitched note with the pick and the higher note with my middle finger. I do use my ring or pinky* instead of the middle every once in a while, depending on which particular string(s) need to be played simultaneously.
* Realistically, I almost never use my pinky, but if it just happens to work out as the best option, I'll use it.
Violeiro
« Reply #3 on: July 18, 2019, 03:36:16 PM »
Thanks everyone. That is how I am doing now....just wanted to make sure there wasn't any special technique out there :)
TG
« Reply #4 on: July 18, 2019, 11:07:16 PM »
depending on what it is, sometimes I use a pick and either my middle or ring finger, or I'll just use the pick and mute the stings in between the ones I want to sound.
1992 Taylor 410
2014 Taylor 214dlxCE
2016 Taylor 816CE
2017 Taylor K26CE
1995 Guild JF30-12
2007 Fender Jimmy Vaughan Strat
2008 Gibson Les Paul Studio
Christhee68
« Reply #5 on: August 27, 2019, 03:42:03 PM »
It's easy if the strings are right next to each other. If it's the 6th string and the 1st string you're trying to pick at the same time--I haven't figured that out yet.
2013 Taylor 314ce
2015 Martin D-18
1982 Martin HD-28
2004 Fender Telecaster
2010 Martin X-Series
Mid 80's Sigma DM-3
