« Reply #8 on: February 15, 2019, 12:58:30 PM »
... I think it might be something inside the body which vibrates at that frequency. But why only when capo’d and why only when the capo is on the 2nd fret and not happening on other frets? Very weird indeed...
Could it be that the cables inside have detached from the body?
On a lark you might try a different capo (i.e., one that's bigger/heavier) and see if that clears up the problem. If nothing else, it would indicate whether my analysis is accurate...
Yes, checked with a different capo (different brand and design). Same exact thing. The guitar must be possessed!
Good job I don't use capos a lot. It's only on Fast Car and Camila Cabello's 'HAVANA' that the capo is on the 2nd fret. Must ask our singer to sing 1/2 a step higher...
Well, kind-of throws that theory out the window...
Double check everything that's supposed to be tight (e.g., tuner posts) are tight. Try taking out the battery holder, just to see if that's the culprit. If you haven't tried changing the string(s), that might be worth a try too. Also inspect the fretboard in the location where the capo gets installed, as well as the second fret itself, for excessive wear or warping; if that string isn't being fully held against the second fret, plucking the string at the 10th fret may cause the string to resonate between the capo and the nut. To test this theory, wrap a rag or handkerchief around the first fret so that none of the strings can resonate behind the capo.
Yeah, I'm probably reaching now, but you're rapidly getting to the point where your only option will be to sprinkling holy water on the guitar/capo...
T5: C1, C5-12, S (Aztec Gold)
