Author Topic: Medium vs. Light strings - is it mainly a question of volume or tone too?  (Read 4984 times)
tremolo arm
I recently purchased a second hand Taylor GS-Ltd, which came strung with 0.012s. The guitar feels comfortable and sounds good too. That said, I note that Taylor recommends that the GS should be strung with 0.013s.
My question is - is this just for volume purposes or does it improve tone too?
I've read opinions on this forum regarding people's preferences on string gauges and brands, but I can't seem to get a clear view on why people prefer the medium strings.
Granted it is a personal thing, does it mainly come down to loudness? If so, I am not so interested in loudness and would rather stick with 0.012s for sheer comfort. If it is tone, then what exactly improves with medium strings compared to light? Is it the bass, note separation, etc.? Is it just on strumming or finger picking too?
If I can help it, I would avoid going up a gauge, because I feel this would deteriorate my fretting accuracy and may ultimately make the guitar less enjoyable.
Thanks in advance for your wisdom and opinion
Taylor 812CE DLX 12 fret
Taylor GS-Ltd. 2011 Fall Cocobolo
Baby Taylor
Gibson Les Paul Custom Classic
Fender Team Built Custom Shop Stratocaster
Fender Baja Telecaster
Duesenberg Alliance Joe Walsh
Gretsch Electromatic 5622T
Epiphone Riviera P90
Epiphone Firebird Bass
Re: Medium vs. Light strings - is it mainly a question of volume or tone too?
« Reply #1 on: February 11, 2019, 07:36:31 AM »
I prefer light gauge strings regardless of the model. A guitar's truss rod can be adjusted to accommodate a change in string gauge if needed. While the common wisdom states that a heavier gauge string is needed to drive the top of a larger guitar (to theoretically maximize volume and fullness of tone), you should stick with the light gauge strings if you're happy with your guitar's sound as it is.
« Reply #2 on: February 11, 2019, 08:40:30 AM »
For me, it is more about tone than volume.  Light, medium, and medium-light gauge all impart a different tone which interacts with a guitar’s bracing and overall build (which includes wood species).  Thus, one gauge is not better than another as much as it differs from one another, and this will vary with each guitar.  The real answer is trying it and deciding for yourself.  The same goes for string composition and brand. The correct choice is the one you prefer.
timfitz63
« Reply #3 on: February 11, 2019, 09:05:39 AM »
My only experience in this matter is actually going the opposite direction:  a used 414ce that I bought a few years back had been strung with medium-gauge strings, whereas Taylor recommends light-gauge strings for the Grand Auditorium (GA); I switched back and made the appropriate adjustments on the truss rod, partly because that's the recommendation of the manufacturer and partly because I find the light-gauge strings more comfortable to play.  Frankly, I didn't note any significant difference in tone or volume -- but I was also going the opposite direction on a smaller guitar body...
To take a poke at answering the root of your question from a largely scientific/physics/engineering perspective:  I believe any differences that could be perceived would be perceived as tonal due to relative loudness:  lighter-gauge strings being 'thinner-sounding' and somewhat quieter -- largely for the reasons given by "SF" (the ability to impart energy to the top).  Larger (i.e., thicker) strings have more mass, which in turn will transfer more vibration momentum better.
All that beings said, though, I would surmise that, like the GA, the sonic difference due to string gauge might be bordering on (if not entirely) negligible for the Grand Symphony (GS) body as well, which has only a slightly larger (1/4-inch) lower bout than the GA; all other dimensions of the GS are the same as the GA.  That means the top has only a bit more surface area.  The medium-gauge strings will definitely be up to the task of driving the top adequately, but I would guess that the light-gauge strings might only run out of gas at the extremes of the frequency response spectrum (i.e., the lowest lows and the highest highs).  So confirmation bias aside, one is not likely to notice any significant difference in tone so much as a small difference in volume -- or perhaps in practical terms, muted tone that requires more effort in strumming/plucking the lighter-gauge strings to get the same volume as medium-gauge strings.  In the end, it's probably a bit of a "chicken-or-the-egg" discussion...
I would opine that this topic maybe only has relevance when applied to the truly large guitar bodies (Jumbos, Grand Orchestras, etc.); those guitar bodies in the midsize range (GA, GS, Dreadnoughts) have probably been determined to be optimal with their respective recommended string gauges, but will do fine with any similarly-gauged string set.
And in the end, Taylor's string recommendations are just that:  a guideline that they provide so those of us who aren't luthiers have a starting point.  Like Edward points out:  in the final analysis it comes down to what your ears hear, and what your fingers find comfortable to play.
T5: C1, C5-12, S (Aztec Gold)
tremolo arm
« Reply #4 on: February 12, 2019, 10:49:14 AM »
Thanks for your wisdom.
I was thinking of trying a set of PB HD lights.
Granted these were developed for smaller guitars, I was thinking they might suit my playing style and the Grand Symphony well. Anyone using HD lights on their Grand Symphony?
Baby Taylor
jpmist
    • Soundcloud
« Reply #5 on: February 12, 2019, 12:50:45 PM »
Good stuff here. Just wanted to throw in the issue of total string tension which wasn't brought up.
My take is that manufacturers suggest a particular set of strings when what they really want to suggest is a set that provides an amount of string tension that the top was designed for the guitar's best sound.
If you really want to get granular about this, D'Addario has an excellent resource that will give you the total string tension of gauges that you specify.
http://stringtensionpro.com
donlyn
  • De gustibus non disputandum
« Reply #6 on: February 12, 2019, 07:51:13 PM »
I don't own any Grand Symphony models, but I do currently use Elixir PB HD lights on both my 818e Grand Orchestra and my 412e-R Grand Concert. The GO had PB mediums on it when I bought it, and I twice changed it with mediums. Turned out that my ears really didn't need any bass bump, and tried the PB HDs next. And have stuck with them for a while. The bass E string not so much, but the change in A and D strings does reduce a bit of tension, and my fingers seem to like it (I bend the 'D' string during 'Apache'). I also got used to the feel and sound of .013-led medium treble strings, which treble strings are shared with the HD unwound lights. the HD 'G' string is in-between their standard medium and light gauges. I believe Taylor normally ships the GS model with medium strings, so you should have no trouble with changing out your GS. For the sake of completeness, I also use HD lights on my mahogany GC and PB HD lights on my EJ 200.
Hope this info is of use. Do let us know how you like the change. After all, it is your ears and fingers that matter most.
Don
« Last Edit: February 22, 2019, 11:13:52 AM by donlyn »
* The Heard:
09 Taylor  all walnut Jumbo
* Tenor Ukuleles:
Kala KA STG
Kala KA APT5 CTG 5 string
Guitarsan
  • Keep calm and play on!
« Reply #7 on: February 19, 2019, 08:15:50 PM »
Also keep in mind that the nut is filed/sized for the string size recommended. So if you move up to mediums from lights, the bass strings especially won’t sit as neatly as designed for maximum tone transfer.
