Author Topic: My 814 feels "hard" on the strings  (Read 3830 times)
Igniten
« on: January 21, 2012, 04:13:38 PM »
I just got my Taylor 814 back from my Luthier. I have had some problem with the B-string. Problem is solved. It was the saddle. They put on new saddle, and the guitar sounds great.
Before they sent it back i had them put on Elixir PB, instead of 80/20, wich i usually prefer. Suddenly my guitar feels hard to play. My finger hurts after an our of playing. The actoin is great. Anybody got any thoughts on this?
If i change back to 80/20, wil the trust rod need adjustment?
« Last Edit: January 28, 2015, 06:19:49 PM by UTGF-Team »
Re: My 814 feels "hard" on the strings
« Reply #1 on: January 21, 2012, 08:07:26 PM »
Hi!  I don't think you'll need an adjustment at all.  :)
« Reply #2 on: January 21, 2012, 10:42:34 PM »
hi Igniten,
i was just wondering where on the fretboard the strings feel more difficult to fret -
is is more toward the first 3 fret or closer to the around 7th to 10 frets or do all
of the strings feel like they are more difficult to fret over the entire neck ???
i hope that the action at the nut & the neck relief were checked, & adjusted if needed -
any chance that medium strings could have been installed, rather than lights ???
switching back to 80/20s most likely should not  require a truss rod adjustment,
provided the strings are of same gauge & the neck relief was correctly set -
if, for some reason, medium gauge PBs were installed & the neck relief set
afterwards, it may  need a minor truss rod 'tweak' when going back to lights
Igniten
« Reply #3 on: January 22, 2012, 02:57:08 AM »
Hi. Thanks for replys.
The guitar generally feels stiffer to play all over.  The neck, as i understand from my Luthier, was given full neck -reset when new saddle were installed.
Could be that they put on medium instead of lights. Funny thing is, i have tryed PB many times before, but i cant remember them beeing so stiff. I`ll try puttng on some 80/20 lights  and see what happens.
AK
Steely Glen
  • UTGF Member #2
« Reply #4 on: January 22, 2012, 08:57:40 AM »
Because of the denser wrap, Phospher Bronze strings are intrinsically stiffer than 80/20s, even of the same gauge.  I've heard it said that PBs will exert 1 lb more tension than 80/20s of the same gauge, which is not much, but enough to be noticeable.  It's possible that that's the culprit.   I'd just change the strings.
Taylor Guitars & Gear:
2010 Taylor 816ce
2011 Taylor 714ce
2005 Taylor 555ce
Taylor K4 Preamp
leeasam
« Reply #5 on: January 23, 2012, 09:44:43 PM »
it is the Phos/bronze strings they ARE stiffer than the 80/20s. At least in the Elixir brand.  I had a CA GX performer with LIGHT Phos/bronze  factory strings)and it played stiffere than my 816CE does with medium 80/20s. My fingers were hurting bad after a good period of time in worship. Like razor blades cutting in where as my Taylor with the 80/20 mediums does NOT.   My boy has a Walden D550 and we treid phos/bronze on it to warm it up and he did not like the feel, said it felt stiffer so we went to the 80/20s.
2010 816CE Taylor
2012 PRS P22 Black Gold wrap around
2012 Taylor GS mini
Satsuki
« Reply #6 on: January 24, 2012, 11:33:08 AM »
I am going to switch to 80/20's. I have been using the Exlir PB's.
