Author Topic: Taylorsense question  (Read 3246 times)
Greg Rabalais
« on: November 10, 2016, 12:23:28 PM »
The previous owner of my 814 removed the expression 2 pickup and had an LR Baggs system installed.  Does anyone have any idea whether that would prohibit swapping over to the Taylorsense thingamabob?
Taylor 814ce-LTD
Minnesotaman
Re: Taylorsense question
« Reply #1 on: November 11, 2016, 11:21:05 AM »
Call Taylor customer service. They are very knowledgeable.
« Reply #2 on: November 12, 2016, 02:13:36 AM »
Taylorsense replaces the existing
output jack/power supply unit -
provided that the harness that plugs into it was
left intact (using the 9V for power), it should work
« Reply #3 on: November 12, 2016, 04:26:32 PM »
The TaylorSense features work independently of the jack.  When I was beta testing the system, I had the uninstalled unit sitting on my desk with a 9v battery installed.  it was reporting temp, humidity and physical shock data just fine via bluetooth to the app on my phone.
Greg Rabalais
« Reply #4 on: November 12, 2016, 06:21:08 PM »
OK.  Thanks.  I ordered it.  We'll see.
Taylor 814ce-LTD
« Reply #5 on: November 12, 2016, 07:17:59 PM »
Like Gutch said, it works independently. I also did the test and now have 4 installed and it seems to be working really well. One seems to read a little high on the humidity but I have a hygrometer there now to cross check it in the case, may be worn out humidipaks.
If they left the ES 2 in the bridge and the board in the guitar with the wire and harness you should be all set.
Good luck,
Greg Rabalais
« Reply #6 on: November 18, 2016, 07:09:03 AM »
Well, I got the Taylorsense module and could not install it.  The entire expresssion system had been removed and replaced with the LR Baggs equipment.  I took it to the local Guitar Center and they couldn't do it either.  It looks like I will have to buy an expression system and have it installed to bring the guitar back to its original configuration before I can install the Taylorsense equipment.  Does anyone here know how much an expression system will cost?
Taylor 814ce-LTD
Craig
    • UTGF Members Map.
« Reply #7 on: November 18, 2016, 10:39:37 AM »
I presume the pickup is still there or there would be holes in the bridge so you only need the preamp.
1978 Music Man Sabre II
1980's Charvel Model 6
2014 816ce First Edition
2014 714ce FLTD Sassafras
2016 GS Mini e Koa
2017 Avalon A2-20c
And an Eastman Mandolin!
Visit the UTGF Members Map
« Reply #8 on: November 18, 2016, 08:01:53 PM »
Hey Greg,
If part of the system is still there(under bridge pick up) it should be an easy install anyone can do. If you aren't sure, Pat Diburro in Exeter, NH is actually authorized to install the system in a non e model so could obviously do a partial, and is closer than sending it to the factory, which I believe is the only other option for a full install.
A call to Taylor customer service or an email to Mr. Diburro would be in order.
http://www.diburro.com
Good luck and let us know how it goes.
Greg Rabalais
« Reply #9 on: November 19, 2016, 08:19:23 AM »
Thanks.
Taylor 814ce-LTD
