Well, I finally put the finishing touches on my guitar cabinet
I wanted to create a humidity controlled display case for my 618e, and I think I did it!
To control and monitor the humidity, I first made sure it was tightly sealed, which I did with weather stripping and sealer all around the thing...
Then i purchased a product called "Music Sorb", which is basically a silica-basecd 2-way system designed to keep the case between 40-60%rh. That is what is in the bag at the bottom of the case.
Then, I added a Cigar Oasis humidifier, set at 47%. It's always plugged in, but only comes on in spurts to keep the humidity constant.
Additionally, and I know I went overboard, I have four different hygrometers in there. A small Taylor hygrometer, which seems to be the most accurate, the D'addario Humiditrak
system, so i can see what the RH is from my phone, a small Accurite hydrometer, and two large color displays mounted on the wall. All if the hygrometers are within 1-2% of each other exempt for the largest color display, which is reading 6% under (I'm going to toss that one out).
For the past coupe of weeks the RH in the house is hovering at 30-32%, and the case is a solid 47-48%.
My wife thinks I'm nuts, and I know I've def gone overboard, but I needed a project!!
