Author Topic: 410CE in classifieds polished to gloss - how???  (Read 6761 times)
thebigz
« on: December 13, 2011, 02:38:20 AM »
I have a new 416CE fall ltd with matte back and sides, I would love to have gloss.  I saw the 410CE in the classifieds and the owner said it came matte, but is now gloss....  curious as to how this is done...
Iplay2
Re: 410CE in classifieds polished to gloss - how???
« Reply #1 on: December 13, 2011, 09:44:38 AM »
I'm going to have to do a little cross posting...and I hope I don't get in trouble for this...
Here are two very good explanations on how to do it.  Enjoy
http://www.acousticguitarforum.com/forums/showthread.php?t=152168&highlight=satin+polish
http://www.tomyoungguitar.com/OrsinoizingPage.html
thebigz
« Reply #2 on: December 14, 2011, 01:39:18 PM »
That looks great.  Thanks.  Any ideas if this voids the Taylor warranty?
Guitar Rodeo
  • World's largest independent Taylor Guitar dealer
    • Guitar Rodeo Company
« Reply #3 on: December 14, 2011, 03:10:04 PM »
Polishing the satin finishes won't void the entire warranty, but I doubt you would be able to count on having finish issues covered. That being said, problems related to the finish are very, very rare. I think (and do not have any authority-I am supposing here) they would probably view the polishing as wear and tear, as it was the result of physical action outside the normal warranty anyway. As always, it might be best to call Customer Service and ask them first. 800 943-6782.
Jim Tordoff
Specializing in Taylor, Santa Cruz, Carmel, Morris, Huss & Dalton and Breedlove Guitars
http://www.guitarrodeo.com
877 487-6336
« Reply #4 on: December 14, 2011, 03:13:24 PM »
note to self : must learn to search & type faster -
Jim beat me to the punch ;)
you may want to call Taylor Customer Service to verify
if there may be any possible warranty conflicts
1-800-943-6782
i would imagine, if anything, that only the finish warranty would be affected,
for instance if the finish were to crack, bubble or peel off at a later date
from what i've heard, satin finish is a 2 coat application, with a diffuser to make it matte &
the gloss finish is 4 to 5 coats, with a good bit of hand sanding, robotic & hand buffing
also, i am uncertain if there is a special procedure or tool required to remove the ES knobs,
in order to facilitate the process of polishing the area around the onboard pre-amp controls -
i've done some searching & at this point i've come up with goose eggs
congrats on the 416ceLTD - GS rosewood, CV bracing, slotted diamond fretmarkers & gold tuners ...
nice :)
« Reply #5 on: December 14, 2011, 05:17:29 PM »
Iplay2 referenced one of the threads I had bookmarked. Here are a couple more:
http://www.acousticguitarforum.com/forums/showthread.php?t=208762&highlight=flitz
http://www.acousticguitarforum.com/forums/showthread.php?t=116828&highlight=polish
I started the process on my 314ce, but because I have such bad problems with forearm tendonitis, I've only finished most of the back. Since I don't have much strength in my arms, I found the Scratch-X just wasn't working well at all for me. A few coats later, and I was quite a distance from the desired result. I switched to Flitz and it cut through quickly leaving me with a nice semi-gloss. When I do get around to work on the sides, I'll bring those up to a semi-gloss then work on the back and sides with the Meguiars polish for a higher gloss.
The edges are the hardest part. I don't know if Taylor used more finish there or what, but the center of the back was FAR easier than the edges. I still need to work on the edges of the back a little more so I don't hear the drag of my fingers when I touch it. :)
thebigz
« Reply #6 on: December 15, 2011, 04:04:02 AM »
nice :)
Haha, that is the most specific congrats I've received!
dcarey
« Reply #7 on: December 15, 2011, 06:12:38 PM »
I've used StewMac Color Tone #4Swirl Remover to polish a couple of Larrivee Om-03's.
I used their drill mounted foam polishing wheel after the initial hand rub.
Here's the results:
After final buff
After final buff
First buff
First buff
Dan
Time flies like an arrow. Fruit flies like a banana.
Satsuki
« Reply #8 on: December 17, 2011, 09:25:41 PM »
Cindy, Dcary did a great job on his guitar using a foam polishing wheel mounted in his drill. You should try that method it seems to be a better method than doing it by hand. Beautiful job, Dcary!
