UPDATED - some new photos below, and a few lines, for when you use your "spare" Taylor machine heads as an upgrade for your GS MiniI posted in
another thread that I wanted to change the look of my 816ce by replacing the machine heads. This modification changes the look of the whole guitar, not just the headstock - super!
I decided that I didn't want to change the originality of my guitar by adding non-stock tuners, for example the popular Gotoh 510 upgrade. But also I didn't want the hassle of modifying the headstock, drilling holes etc. The solution? A new set of Taylor machine heads in a different colour, and some Schaller Ebony buttons that fit the Taylor/Ping machine head with NO additions or alterations. This is a mega-easy modification - everything is "plug and play". If you want some instructions, or just some top-tips, please add a comment and I'll start a new thread.
The look I wanted and perfectly achieved is the gold machine head with ebony buttons (and gold fixing screws). This is exactly what I wanted, at a fraction of the price of the Gotoh upgrade, and now I have a selection of parts that I can use to change the look any time I want - win, win, win!
The first photo is my first choice. The other photos cover all the other possibilities, in case anyone is thinking of the same modification, but is uncertain how the headstock will look.
Gold tuners, ebony buttons with gold fixings (don't forget to change the truss rod cover screws to complete the look)...Original gold tuners and nickel tuners Front and back, gold tuners with ebony buttons Front and back, nickel tuners with ebony buttons Nickel/gold fixing screws Black fixing screws And don't forget to finish off the look with a nice gold strap buttonThere have been a few questions about the quality of the stock GS Mini machine heads, comparison with the standard Taylor branded machine heads, and if the standard ones will fit the Mini. Here is what I found out when recently swapping my Mini machine heads for my new "spare" Taylor branded Ping tuners...
First of all, this is an upgrade. When you get the two tuners side by side on the bench, you can clearly see the difference in quality - the casting and finish is noticeably better on the Taylor branded tuner (on the right). And in my opinion, the chrome finish on the Mini tuner looks cheap compared to the Nickel finish on the standard Taylor tuner. Also interestingly, Taylor had the fore-sight to provide the extra locating hole required for fixing the Taylor branded tuner (as if Taylor was anticipating this upgrade). This means that the Taylor tuner can be fitted without any modifications to your Mini - bonus! Here you can see front and back a comparison of the two machine heads and how they will look on your Mini. I already mentioned the colour difference, but also the Taylor housing is slightly bigger, and the Taylor buttons are quite a bit bigger.
Action-wise, I had no complaints with my original Mini tuners - my Mini was easy to tune and stayed in tune. However, when you have the opportunity to test the two tuners side by side on the same guitar, I found the Taylor one was smoother and more responsive, so again, definitely an upgrade in quality Finally, a before and after side-by-side. Because the changes are only noticeable if you know what you're looking for, this upgrade doesn't alter the overall look of your guitar, but it is a quality upgrade.
One last thing - I personally don't think the larger buttons look out of place on the Mini. But the two sets of buttons are interchangeable if you prefer to use the small ones (but look out for the subtle colour difference...)
