Author Topic: Need help troubleshooting my 210e.  (Read 1566 times)
davidwolfe
« on: June 25, 2014, 10:56:13 AM »
I've got this storage problem with my guitar. When the battery dies, and it's plugged in, it makes an obnoxious and very loud buzzing sound. I'm not sure if this is a common problem or not, but I was hoping you guys could help me pinpoint the problem.
Also just for clarification, this is the 9v powered ES-T.
Re: Need help troubleshooting my 210e.
« Reply #1 on: June 29, 2014, 04:52:21 PM »
i would suggest removing the battery if the guitar is not going to be played for a while -
the ES-T preamp has a LED battery indicator, which lights up when the cable is plugged in,
but unlike the LED on the older fishman barndoor preamp, which was a low battery indicator
if it stayed illuminated when the guitar was plugged in, the ES-T LED shows there is power,
but it doesn't not indicate how long the battery will be good for (on the ES, it's about 40 hr)
a battery tester that shows the capacity of the battery, in addition to voltage would be a good idea, imho
http://www.lightinthebox.com/bt168-universal-battery-volt-tester-aa-aaa-c-d-9v-button-cell_p1299095.html?currency=USD&litb_from=paid_adwords_shopping&gclid=CLiNuOz6n78CFXMR7AodFzMACA
hope this helps
WELCOME ! ! !
MikeB
« Reply #2 on: June 29, 2014, 07:44:40 PM »
Do you mean that when you play it with a dead battery it makes the bad sound, or just plugged in, not playing it?
davidwolfe
« Reply #3 on: July 04, 2014, 08:25:49 PM »
Plugged in and playing with a nearly dead battery at first. Then after it gets really dead, it just puts out a constant buzzing sound.
