Author Topic: Has anyone changed to medium gauge on the GT?  (Read 6325 times)
BarbMaxey
  • Sound... makes movement...
    • ReverbNation
« on: May 07, 2024, 11:06:22 PM »
I have the 811 GTe with 12-53/54 gauge strings. Has anyone tried going to medium gauge 13-56 strings? If so, do you like them? Did you have to change the setup? Thanks.
Barb Maxey
www.reverbnation.com/barbhamiltonmaxey
https://www.youtube.com/user/sixstringvibes
2025 Taylor T5z Custom Koa
2011 Taylor GT 8 baritone
2021 Taylor GT811e
2013 Taylor 716ce
2013 Taylor GS Mini Mahogany
2011 Taylor T5 X
2005 Taylor T5 S-1
2015 Epi 339 Pro
2009 Composite Acoustic Cargo
2001 DeArmond Bass
Re: Has anyone changed to medium gauge on the GT?
« Reply #1 on: May 08, 2024, 05:39:18 PM »
I have medium-gauge strings on my 114.  If left in normal tuning (E to E) you can notice the thicker strings and increased string tension.  But I keep the guitar tuned to open D or sometimes D to D, both of which nicely offset the added string tension, and I haven't needed to touch the truss rod.  If you tune D to D, you can always put your capo at the second fret to get the equivalent of E to E tuning.
« Reply #2 on: May 09, 2024, 10:27:26 AM »
Barb, the 24" scale length of the GT automatically means less tension than other models at 25.5" or even 24.8" for the GC.  The reduction is about 9-10% overall.  Mediums at 25.5" scale are about 180 pounds total, and at 24" scale they become about 162 pounds -- almost exactly the number for 53-12 light gauge on a longer scale length.  That is why the GS Mini (23.5" scale length) comes with mediums as standard.  It takes a heavier string to offset the shorter length.  As Dennis said, tuning down one half-step across the board accomplishes the same thing.  You are back to the tension of light gauge.  Tuning down a whole step is even looser.
It is doubtful that you would have to change the setup unless the thicker strings are binding in the nut (pinging as you tune up or down).  Worst case, you might need a quarter turn on the truss rod, but probably not.  Most of my Taylors wore light and medium gauge, with no ill effects.
BarbMaxey
    • ReverbNation
« Reply #3 on: May 09, 2024, 07:48:36 PM »
Thank you so much for that info. I’m going to try it then!!
Barb Maxey
2021 Taylor GT811e
2013 Taylor 716ce
2011 Taylor T5 X
2005 Taylor T5 S-1
2015 Epi 339 Pro
2001 DeArmond Bass
« Reply #4 on: May 10, 2024, 10:06:43 PM »
Not exactly the same change, but I put on medium-light Elixir nano PBs on a GC body and I love it.  Had it like this for over a decade: sounds great, plays great, no desire to change.  Give it a whirl!
BarbMaxey
    • ReverbNation
« Reply #5 on: May 22, 2024, 07:21:47 PM »
Barb Maxey
2021 Taylor GT811e
2013 Taylor 716ce
2011 Taylor T5 X
2005 Taylor T5 S-1
2015 Epi 339 Pro
2001 DeArmond Bass
