Author Topic: Silly question - But, still asking. T5 for everything - Acoustic and Electric?  (Read 6114 times)
kh1967
I know a lot of people love their T5, as do I.  But, I was wondering if anyone liked it well enough for both acoustic and electric that you abandoned your acoustic guitars and only play a T5?
Have you found enough satisfaction with just the T5?
This is how I look at a T5:
On one end of the spectrum, you've got a Martin D28. On the other end of the spectrum you've got a Les Paul:
D28        LP
  I----------------------------------------------------------I
The T5 isn't going to completely replace either one but, sonically, it'll cover a good 85% of what's in between the two:
D28                               T5                                 LP
I------(---------------------------------------------)------I
kh1967
D28        LP
D28                               T5                                 LP
Great visual and great answer - thank you!
Happy to be here, proud to serve...
« Last Edit: February 21, 2012, 09:04:53 PM by Left Coaster »
I've played plenty of gigs with only a T5 and it worked out great.  The preamp in the T5 provides some of  the cleanest, high fidelity, most musical sound you will ever get out of an electric stringed instrument.  The secret is in how/where you send the signal once it leaves the guitar.
If you are plugging the guitar exclusively into an electric guitar amp, do not expect it to sound like an acoustic guitar.  That kind of amp isn't designed to reproduce the highs that you expect to hear from an acoustic.  You will, however, get some killer electric tones from the T5.  Go into switch positions 2 through 5 and tweak the tone and volume to your heart's content.  It takes effects really well too.
Taylor clinician (and all around great guy) Marc Seal, shows off the perfect way to run a T5 at each of his road shows.  Take the signal from the T5 into an A/B/Y box.  Take the 'A' signal output and run to your Acoustic amp or direct to the PA (via a DI).  Take the 'B' signal output and run it to your electric guitar rig.  Now you can have acoustic, electric, or BOTH at the same time (which sounds KILLER!).
Because the T5 has a balanced output (like the acoustic ES), a variation on this theme (and the way I do it) is to use a Taylor balanced breakout box in place of the A/B/Y.  Use a balanced TRS/XLR cable from the T5 to the breakout box.  Use the unbalanced 'TUNER' output of the box to feed your electric rig, and take the balanced pass through signal direct to the PA, house system, or your acoustic setup.  To mute the acoustic signal, hit the 'MUTE' switch on the breakout box. My electric pedal board is a Boss GT-10, so to mute the electric signal is kick down the volume pedal.
I can't speak to this from personal ownership, but can say that it "can" be done, but it's up to you.
For example: last road show there was Marc Seal (sp?) who played a T5 and got amazing tone out of it.  Simple reason: he had A/B'd his signal, one into the PA for agoustic tone, the other into a tube amp for electric tone.  Hence, good tone for both camps.
That said, would I do it?  Heck no!  I love my Strats and Pauls too much to relegate myself to a T5, which is nice to be sure, but a Strat and Paul have got my tonal DNA wrapped up all in there.  And give up my acoustic Taylors??  ...no freaking way as I dig the Taylor acoustic vibe!   So in the real sense, you can get pretty good acoustic tone as well as really good electric tone, depending on your rig, but totally do-able.  The real question is whether you want to.
« Last Edit: February 17, 2012, 04:42:41 PM by Edward »
tnfiddler
  • Education is important! Guitar is importanter!!
I LOVE my T5.....but, just recently bought a 614ce so I can plug it in too.  After practice the other night, our bass player told me that I should be playing an acoustic on some of our songs in the setlist because it would sound more country and then use the T5 on the other upbeat, recent country songs that are more rocking than the traditional stuff.  So now I just switch back and forth between the two.
1995 810
2016 GS Mini Koa ES2
2014 Bourgeois SS Adi/Hog Custom dread
2006 Charles J. Horner fiddle
a friend just got a T5-X ovangkol to complement his 410ce -
i think that more in terms of the feel & 'vibe', an active top electric/acoustic
is probably  not going to replace an acoustic &/or an electric because
the feel of the guitar is considerably different, as it does not have the girth or
resonance of an acoustic & it is not a 'true' 'rock n roller' like an electric
i think that it can be very versatile & will work well in a good number of situations,
especially if swapping guitars is not an option (if you're the only guitar player) i.e.
acoustic fingerstyle intro, hi-gain power chordng/lead solo, acoustic strum,
acoustic fingerstyle outro ... or, one could get a stand for the acoustic :)
http://4.bp.blogspot.com/_3qkgPpUPLtk/RrNrH85frYI/
AAAAAAAAAmU/MZOQ7zuOAsw/s400/carlos+accousticbig.jpg
tnfiddler
I just recently discovered the joy of switch position #3!   I don't ever use any other position now! It just gives me the electric sound I am looking for. #3 is the bridge pickup by itself in case any non-T5 owners were wondering.
1995 810
Position #3 is my favorite on the T5...
Iplay2
I am an acoustic player through and through, while my gig partner plays his Fender and Gretch for most of the set.  I have gone back and forth on getting a T5, but I just can't bring myself to pull the trigger.  I don't know...they are just so close to the dark side.  ;)
Captain Jim
Through all the guitars over the years, my favorite is still the Gibson ES-335 I bought new when I was 13... it's the only one I can't give up.  Les Paul, Strat, a Gibson Gospel, and a slew of others... all gone.  I am enjoying the heck out of the 114ce I bought last month, but the guitar salesman also brought out a T5 - not even close to the "travel acoustic guitar" I was looking for.  The T5 is the first guitar that made me think, "Ohhhhh, I'd consider trading off the 335 for that..."
Yeah, it was that good.  If I were playing consistently through an amp, I think a T5 would be a very viable choice.  Unlike many of the collectors here, I've never owned more than 3 guitars at the same time, and usually just two.  I would consider going back to 3 if I could find a valid reason to convince the Blonde that has been at my side almost as long as the 335.  Truth be told, she was lobbying for the T5 when I picked the 114ce.
Sorry, my mind started wandering again - back to the original question: it depends on the playing situation... but, I really like to have a "real" acoustic for my "quiet time."  ;)
Best wishes,
Captn Jim
2014 Taylor 522ce 12-fret
2012 Taylor 814ce
2006 Taylor T-5
2011 Taylor GSmini
2013 Rainsong Shorty SG-FLE
Gibson ES-335-TDC (1965)
Bose L1 Compact
Roland Cube-ST
