Author Topic: Noisy Pot  (Read 2499 times)
ebick
Noisy Pot
« on: March 25, 2020, 11:15:18 PM »
I’m pretty sure that this is a basic resolution, but just want to through it out here.  The volume knob on my T5S has a strong tendency to be noisy.  When it’s acting up, just touching it is all it takes.
So, I have some DeoxIt.  I just pull the knob off and spray that in there, correct?
2006 Taylor T5S
2011 Taylor 814ce
2012 Taylor 214ce-n
2011 Taylor GS Mini
2012 Blueridge BR-40
2012 Alvarez ABT60
1982 Alvarez Yairi DY-46
1980 Gibson ES-175
1976 Gibson SG
1992 Yamaha FG-420-12A
2013 Squier Jaguar VMS Bass
2014 Squier Jaguar VMS Bass V
2013 Dean EAB
416ce
Re: Noisy Pot
« Reply #1 on: March 27, 2020, 08:27:43 PM »
Dirty pots or bad/loose install and connection. But overall faulty. ???
Re: Noisy Pot
« Reply #2 on: March 28, 2020, 12:02:30 PM »
Wait, not sure if I understand correctly: if "touching" the pot (metal knob or not?) silences your noise, then you have a grounding problem, and this has nothing to do with a pot's innards.  DeOxit is marvelous stuff for cleaning connections, but if what you describe is the case, you need to dive deeper:
1. Is the noise you hear when plugged in with hands off all metal parts?  Then when you merely touch the vol knob that noise goes away?
2. If the above is true, will touching another metal part silence the noise?
3. If the knob is not metal, then is turning the knob inducing scratching noise, or maybe lots of turning silences the noise? ...if so then here is where you do, indeed, have a dirty pot whose guts could use a spritz of DeOxit.  If this is the case, spraying through the top of the pot is a tough call as to whether enough solvent will get into the pot such that the wiper and carbon trace on which it rides will get cleaned off.  The proper method is spray through the lugs area to ensure the insides get fully cleaned and coated.
« Last Edit: March 28, 2020, 12:07:16 PM by Edward »
ebick
Re: Noisy Pot
« Reply #3 on: March 28, 2020, 05:24:35 PM »
I hadn't heard back and moved forward......took the knob off, sprayed the deoxit, worked the knob back and forth....all better......for now at least.
2006 Taylor T5S
2011 Taylor 814ce
2012 Taylor 214ce-n
2011 Taylor GS Mini
2012 Alvarez ABT60
1980 Gibson ES-175
1976 Gibson SG
2013 Dean EAB
Re: Noisy Pot
« Reply #4 on: March 28, 2020, 10:36:30 PM »
Cool beans! :)
