Author Topic: ES2 observations.  (Read 1373 times)
Craig
    • UTGF Members Map.
ES2 observations.
« on: February 11, 2018, 05:54:48 AM »
As much as I love my Taylors I've never been too happy with the plugged in sound, I've done all the usual adjustments but still can't get rid of that certain honkyness that occurs on some notes.
Anyway, for my electric rig I have a Line6 Helix which has just been updated with some new reverbs so I decided to plug my 816 into the Aux input and see what they sounded like.
Straight in to the Aux input and listening on headphones it sounded like I expected, then I tried the guitar in and it sounded great.
Now the thing about the Helix guitar input is that it is of a controllable variable impedance. Dialling through them, the usual 1M sounded bad but dial it down to 90K and it sounded great, lower than that sounded not so good again.
So the first pedal on my acoustic board is a TC Bodyrez which as in input impedance of 1M so I'm going to try terminating that with 100K and see how it sounds.
I'll let you know
Craig
1978 Music Man Sabre II
1980's Charvel Model 6
2014 816ce First Edition
2014 714ce FLTD Sassafras
2016 GS Mini e Koa
2017 Avalon A2-20c
And an Eastman Mandolin!
Visit the UTGF Members Map
nhbiker1961
    • My duo
Re: ES2 observations.
« Reply #1 on: February 11, 2018, 07:29:38 AM »
The Body Rez definitely helps. I have been fighting the battle for years with the Es1 all the way to the new ES2 even with the ESt pre-amp and I am still not happy. My Taylor becomes my 2nd guitar at gigs now not my primary. About six months ago I went to a hybrid that actually on stage sounds better than my Taylor plugged in.
« Last Edit: February 11, 2018, 07:33:50 AM by nhbiker1961 »
Taylor 414ce
Taylor 214ce
2-Godin A6
Fender-strat
Fender-teli
Peavey
Washburn 12 String
Godin SD
Epiphone Red Dot
Wahburn dobro
Les Paul
Peavey Bass
2 Fender Basses
Acoustic bass.
Craig
    • UTGF Members Map.
« Reply #2 on: February 11, 2018, 10:37:09 AM »
OK so I recorded this, guitar straight into a Scarlett interface (1M impedance) into Reaper.
The three takes were recorded identically (just a bit of low cut and reverb) but for the 2nd take I had a 100K resister across the input.
To me the 2nd take sounds more natural.
Please excuse the playing, I'm in a scientific not artistic mood :-)
https://www.dropbox.com/s/qgjrlwkophc24g3/Taylor%20Test.wav?dl=0
Craig
2016 GS Mini e Koa
2017 Avalon A2-20c
nhbiker1961
    • My duo
« Reply #3 on: February 11, 2018, 03:15:47 PM »
I agree on the 2nd. Still lacking something. Compression? I feel your pain, this was my frustration playing live and the louder the venue the more dissatisfied I was.
Taylor 414ce
Taylor 214ce
2-Godin A6
Fender-strat
Fender-teli
Peavey
Washburn 12 String
Godin SD
Epiphone Red Dot
Wahburn dobro
Les Paul
Peavey Bass
2 Fender Basses
Acoustic bass.
Craig
    • UTGF Members Map.
« Reply #4 on: February 11, 2018, 04:10:31 PM »
You're probably right about needing a bit of compression but  it was just an experiment. You wouldn't normally record acoustic direct. If you also think that it sounds better with the lower impedance load then it will try it on my live rig and maybe record the di from my amp.
2016 GS Mini e Koa
2017 Avalon A2-20c
Sprintbob
« Reply #5 on: February 19, 2018, 06:12:39 AM »
What I hear in your recording is the piezo quack that you’ll have with any undersaddle pickup. The only remedies I believe to be effective are a Tonedexter preamp if you want to play live or record using just the guitar pickup or you use a mic(s).
www.audiosprockets.com
I got a Tonedexter in January. It’s easy to use and the results are impressive.
Collings 0001A (Adi/Mahogany)
Cordoba GK Pro Negra (Spruce/EIR)
Froggy Bottom H-12 (Adi/EIR)
Rainsong P-12 (all carbon fiber)
Robinson 12 Fret SS Dread (Spruce/Mahogany)
Santa Cruz Skye 00 (Adi/Cocobolo)
Taylor 714ce 12 fret (Cedar/Koa)
Taylor K-22ce 12 fret (all Koa)
Taylor 562ce 12 fret (all Mahogany)
Craig
    • UTGF Members Map.
« Reply #6 on: February 19, 2018, 10:26:38 AM »
I have heard of them and they sound impressive, I'm not sure if they've made it over to the UK yet though..
2016 GS Mini e Koa
2017 Avalon A2-20c
