Author Topic: battery life question  (Read 1000 times)
gscratch
« on: January 14, 2018, 11:06:47 PM »
I have a 2012  310ce that I play every day, not plugged in.
I plug it in every other week for about 2 hours at a gig.  The battery only lasts about 4 - 5 hours total which seems short to me.
Is this the battery life that others have seen ?
Thanks
2017 Oscar Schmidt 45ce
2017 Taylor 512ce 12-fret
2016 Kala uBass
1973 Guild D-25 mahogany
2012 Taylor 310ce
2013 Taylor 456ce
2014 Peavey Composer ukelele
2005 Rick Thum 17/17 hammer dulcimer
Re: battery life question
« Reply #1 on: January 14, 2018, 11:54:32 PM »
No, you should be getting about 40 hours out of a 2012 ES system.
When you say the battery lasts between 4 and 5 hours, are you referring to actual playing time or plugged in time?  You may already know this, but since the system features a preamp, it's drawing power whenever it's plugged in.
« Reply #2 on: January 15, 2018, 11:38:30 AM »
1. When you gig, is the guitar sitting on a stand beforehand, as well as during setbreaks, still pluged in?  Just as Dennis said, a cable plugged into the guitar counts as "on" so you need to account for those moments in your overall use. FWIW, I always unplug ...always.
2. Are you using a good alkaline such as Duracell or Energizer?
If you're good with the above, then yessir, you've definitely got something wrong going on with the preamp.
« Last Edit: January 15, 2018, 11:40:19 AM by Edward »
gscratch
« Reply #3 on: January 15, 2018, 02:01:57 PM »
thanks for the replies.
I usually plug in during the sound checks and unplug when packing up, so it's plugged in during the entire time; usually two hours or so for the gigs we've been doing recently.
I'll contact Taylor Customer Service.
2016 Kala uBass
2012 Taylor 310ce
2013 Taylor 456ce
PaulWood
« Reply #4 on: January 17, 2018, 07:37:53 AM »
I have an 812e with ES1.3 retro-fitted. I play it plugged in virtually every night for an hour, very occasionally I might choose another guitar, but that's the exception. I've noticed that my batteries last about a month, give or take - 4 or 5 hours sounds wrong. Are you using decent batteries, like Duracell coppertops? If so, I'd have the electrics checked out at your local Taylor service centre.
KM Frye
« Reply #5 on: January 18, 2018, 09:06:53 PM »
I've played my T5z daily since early April. Still ticking along, as they say....
I do unplug the cord before I set it back in the stand, however.
Kevin Frye
Composer, conductor, player
Taylor T5Z
Rickenbacker 370/12
Gretsch 6122 CG
Fender FJ
Beaver Creek classical parlor guitar
