Author Topic: switching standard Taylor tuners for Gotohs  (Read 5381 times)
miksel
« on: January 16, 2012, 07:56:58 PM »
I apologize for "blitzing" the forum with questions but with a forum devoted to Taylor its just hard not to let loose ! :)   How difficult is it to have standard Taylor tuners switched out for Gotohs ?(not by myself but by a qualified Taylor repairperson) Would it involve additional holes to be drilled,etc.? Thanks,Mike S.
Re: switching standard Taylor tuners for Gotohs
« Reply #1 on: January 16, 2012, 09:41:00 PM »
tthe questions & responses are what makes the place roll ..
let'er rip, mike :)
if your guitar has the Taylor branded tuners (phased-in in 03) with no external set
screws, there will need to be set screw holes drilled in the back of the headstock
if your guitar has the Grover tuners with the center set screws (at the 6 'o clock position),
Gotoh used to make 510s with center set screws, but they may  have been discontinued :(
if your guitar has Schaller (M6) tuners (used on very early models & pre 03 PSs)
the Gotohs with the (standard) offset set screws should be a drop-in replacement
a good tech should be able to get you hooked up with no problems & if you haven't
had a chance to try out the Gotohs on a guitar yet, i think you're in for a treat ...
they are s-m-o-o-t-h  8)
« Reply #2 on: January 17, 2012, 04:04:22 PM »
Hi Mike,
Welcome aboard!!
To respond to your question: what michaelw said! :D
And if I may add, swapping tuners is easy enough to do on your own.  Go slowly and remember the addage, "measure twice, cut once."  Simply think the task through, make your markings, check again, and go for it!  BTW, over on the AGF, do a search and you'll find a long thread, complete with pics and helpful tips, on many folks who have done this upgrade.  I've personally done two (three if you count upgrading one guitar to non-Gotohs).  Have fun ...and post pics of your success!
« Reply #3 on: January 17, 2012, 05:11:02 PM »
Here is a post from the AGF which tells the method of changing out the tuners for a set of Gotohs. I thought there was a pictorial tutorial over there, but I haven't been able to find that thread.
http://www.acousticguitarforum.com/forums/showpost.php?p=2508598&postcount=5
Roseadi
« Reply #4 on: January 18, 2012, 03:14:31 AM »
Here's the link with the picture version. As stated above, go slow, and go easy with the drill.
http://www.acousticguitarforum.com/forums/showthread.php?t=143697
coldshot
  • Express Yourself
« Reply #5 on: January 18, 2012, 03:23:51 AM »
G day Mike,
It is an east upgrade to perform yourself. Like Edward said "measure twice" I've done it to all my Taylors past and present, a worthwile upgrade.
After changing tunners on a few of my guitars, i kept the trend going and now do all my own set-ups and set up guitars for customers now also.
You can find any information on the internet these days and www.frets.com is an abundance of great info.
I'd say go for it.
2004 Taylor GA5
2006 Taylor T5 Koa
2010 Gibson 335 Custom
1995 Gibson J35 Ltd
2000 Gibson L5 CES Custom
« Reply #6 on: January 18, 2012, 09:22:23 AM »
Roseadi, THAT's the post I was trying to find! Thanks! :)
« Reply #7 on: January 18, 2012, 06:17:20 PM »
I agree,easy switch.If you have to drill screw holes,mark the desired depth on the bit w/a piece of masking tape.When putting the screws in, dip the threads in dish washing liquid,pat w/a dishcloth,and you have great lubrication as well as a little swelling of the wood for a good tight fit.Works well for strap buttons also.
« Reply #8 on: January 18, 2012, 06:23:27 PM »
... When putting the screws in, dip the threads in dish washing liquid,pat w/a dishcloth,and you have great lubrication as well as a little swelling of the wood for a good tight fit ...
Actually, you should never use any kind for soap on screws going into wood.  Soap and detergent are both alkaline in pH, and can accelerate rusting of the screws if moisture ever gets in there.   Instead, use paste wax as a wood screw lubricant.
« Last Edit: January 19, 2012, 08:09:28 AM by cjd-player »
« Reply #9 on: January 18, 2012, 08:40:13 PM »
Alkaline?
Is that pink or blue? ;)
