Author Topic: gsmini neck adjustment  (Read 2186 times)
Jimmer
  • My first Taylor is a GS Mini
« on: May 10, 2016, 06:53:07 PM »
Just want to make sure I have this right and any advise would be appreciated.
Here's what I have.. I press the string at the 1st and 14th frets ... the string (low e) touches the 6th fret. That means I have a bow .. yes?
I adjust by turning the trust rod counter clock wise?
Thanks in advance
GSMini
214sb
Re: gsmini neck adjustment
« Reply #1 on: May 10, 2016, 07:33:18 PM »
Unless I interpret your post wrong, it sounds like you do not have enough bow (relief).  The neck is too straight (truss rod too tight) and the string touches when you hold it down, the neck is definitely too straight.  I think you need to loosen the truss rod just a bit to add some relief or bow by turning CCW when viewed from the peg head.  I only adjust truss rods one "flat" at a time, and keep track of how many flats I've turned.  An Allen wrench has six sides or "flats", so I adjust by 1/6 turn at a time.  One or two flats is usually enough to make any adjustment I want.
I have the truss rod adjustment tech sheet on my computer.  I was going to post a link here, but the Taylor web site is off line right now for upgrades.  Ping me with an email at noisebuster@gmail.com, and I can send it directly.  The pictures make this all much clearer to understand.  The tech sheet says that you should have 0.01" or the thickness of a business card between the 6th fret and the string when fretting at 1 and 14.
« Last Edit: May 10, 2016, 07:43:27 PM by Earl »
« Reply #2 on: May 11, 2016, 10:34:13 AM »
PM and email sent, Jim.
Jimmer
« Reply #3 on: May 11, 2016, 10:58:21 AM »
Thanks Earl.. got it
GSMini
214sb
