« Reply #7 on: April 15, 2016, 04:41:24 PM »
I do think that those octave sets contribute tremendously to the tone of a 12 string. I have tried removing the E and A octaves and then beefed up the main E and A strings to a higher gauge. However, I didn't like the effect.. as I decided that if I want to play a 12 string guitar... which I love... then work with the way it is designed. So... that theory led me to where I am now, and love the result, which is to put together my own sets of medium gauge strings. I have noticed that the E octave is... for some reason... unduly thick for it's purpose, so I cut it's gauge back from .030 on a medium set.. to an .025..and bump up the primary string to a .054... which brings out more noticeable bass from that set. As for the A set of strings, I have put an .018w (they are available) or cut back to an .016 in place of the unwound .020 on a medium set. Also... on the D set, I will replace the .014 octave with an .012 string. I like to cut back the G strings to a .022/.009 to tame them a bit...since the G (@.025) and the E octave (@.030) share the highest tension in the medium set!... and to even out the string balance a bit overall. This crazy plan came about using Daddarios String Tension site, so that I could balance out the tension and get plenty of bass also.
This works great on my Guild... giving it a bit more dominant sound on the primary strings... and sends the octaves strings' strong volume to the back. I love it's bassier tone and more even tension across the set. I do tune the guitar down at least 1/2 step as recommended... but it can play up to concert pitch for a short Sunday morning use for the children's 2 worship services without having to use a capo.
Is all this worth it? To me it is... I just buy a medium set.. and a couple extra strings to put this set together.
This is genius, and Tim, that is an interesting query, i could almost imagine the neck wanting to twist. But if the person increased the gauge of the E and A, as Joseph suggests, I bet that would compensate some and prevent it...maybe we can get those myth busters guys to test it? Ha!
Yeah, I thought the same thing about Joseph's method: increasing the low "E" and "A" string gauges might do the trick to re-balance the whole neck, side-to-side.
Somewhere out there on the interweb is probably a method of determining the tension on a given string gauge at concert pitch; in fact, I seem to remember it being discussed here on this forum at one point. Using that method and a bit of math, one could pretty easily figure out exactly what combination of heavier (but solo) "E" and "A" string gauges would balance the neck in the same manner as the standard 12-string "E" and "A" octave-pair gauges. But I'm probably splitting hairs with my engineering approach...
T5: C1, C5-12, S (Aztec Gold)
