Author Topic: Thanks Thalia Capos!!! THREE capos to give away! Contest runs through Dec 13th!  (Read 14512 times)
Hello UTGF Family!
Thalia Capos generously donated 3 of their capos to give away on our forum! Thalia Capos made their mark on the capo world as being on of the first to customize different types of inlays!
They generously sent us the following capos as prizes!
1. "Satin Gold Finish with Dragon Abalone Inlay"
2. "Black Chrome Finish with Hawaiian Koa Celtic Knot Engraved Inlay"
3. "Black Chrome Finish with Hawaiian Koa Inlay"
Here's my review!
Packaging: Thalia Capos doesn't mess around.  Each capo had a hard, clear, plastic case.  If that wasn't enough, each plastic case came in a black microfiber bag.  So it's up to the winner of the capos to decide how they want to store it.  The Thalia capo fits nice and snug in the plastic case and WILL NOT rattle around.
Capo appearance:  The capo is a little bit thicker than say the G7th, Shubb or the Kyser but understandably so as it features unique inlays that other capos don't. The inlays are beautiful and are small works of art in and of itself.  If you go to their website you see all the many varieties of inlay that they offer.
Capo performance:  This capo is solid and very well made!  This capo took a little bit to get use to as it clamps down from the bottom side of the guitar neck versus other which are designed to clamp down from the top side.  Squeezing the clamp together actually opens it up. It took a little bit of force to open which I'm sure will get easier with use.  Thalia's capos aren't adjustable tension wise which means that you won't have to worry about getting the tension just right etc.  It has a strong grip and won't fall off.  I did notice that the low "E" string was hit and miss, sometimes being perfect and then sometimes slightly sharp...I'm not worried about this part as it's explained in the next paragraph.
This second part is also where Thalia sets itself apart from other capo companies, as if the neat inlays weren't enough. Thalia realized that different guitar necks have different radii etc.  Most capo companies have one curve to the top part of the capo hence why it's made of rubber.  With each capo comes a number of "sliding" fretpads that can be tailored for your guitar! These are slightly harder than your typical rubber pads and are designed to make sliding moving the capo easier. There are instructions as to how to remove the current pad.
Thalia also sent our forum a set of custom "rubber" pads too should you want the rubber pads instead of the slightly harder "sliding" pads.  The rubber pad kit IS NOT included with the purchase of one of their capos. Only the "sliding" kit comes standard with each capo, but because Thalia is awesome, they included the rubber pad kit along with standard sliding kit! Each capo prize will have both kits to experiment with!  These different custom pads will allow the capo to apply equal pressure across the radius of the neck which should eliminate any type of note distortion aka, your low "E" string going sharp etc.
Capo quality:  As stated above this is a very well made capo. It is larger, but again it's because of the different types of inlay. How confident is Thalia in their capos?  Confident enough to offer a Lifetime Warranty which you can read about on their website!  You don't have to worry about Thalia NOT standing behind their product.
In the end, this is a great company and they definitely have in a small way, revolutionized the capo industry with both the inlay options and the customized padding so that you get the perfect fit regardless of the guitar brand.
Here is where YOU come in! As stated before Thalia Capos graciously donated these capos for prizes on the forum!  3 Lucky winners will each win one of the capos with the extra rubber padding kit included!
Here's how the contest will work:
1. The contest will run through Sunday, December 13th at midnight Central Time, simply reply to this thread to enter.
2. Each person is allowed only 1 entry.  Multiple entries will be disqualified.
3. State which one you would pick first and then which one you would pick 2nd (The first person picked (at random) will have their first choice. The 2nd person picked (at random) will win their first pick IF it's still available or their 2nd pick if available. The 3rd person will win the remaining capo.)
4. That's it!  Good luck!
I will mail each winner their new capo.
Please join me in thanking Thalia Capos for graciously donating 3 capos to give away!
Check out their website at:  http://shop.thaliacapos.com/ and give them a follow if you use Twitter @ThaliaCapos
Here are some pics!!!
lookinup
  • Leap and the net will appear
OK, I'll go first. Beautiful capos -
first choice - Middle one Celtic Knot design,
second choice - one on the right Koa Inlay design.
Thanks for the opportunity!
« Last Edit: November 14, 2015, 09:03:25 AM by lookinup »
2015 Taylor T5z
2015 Taylor 712e 12 Fret
2015 GS Mini (hog)
I'm in...#1 abalone dragon design;  # 2 koa Celtic design
Thanks Josh!
donlyn
  • De gustibus non disputandum
ok, i would like one too.  really diggin' on the celtic knot capo, so that would be choice #1.  being of irish descent doesn't hurt either.
dragon abalone inlay would be #2.
thanks for doing these giveaways.
don
« Last Edit: November 14, 2015, 12:46:52 AM by donlyn »
* The Heard:
09 Taylor  all walnut Jumbo
* Tenor Ukuleles:
Kala KA STG
Kala KA APT5 CTG 5 string
Psi
Cool, not seen Thalia capos previously, and they look kinda neat.
Please mark me down as 1/ Abalone/gold and 2/Standard koa/black chrome
Thanks Thalia and jjrpilot-admin for the opportunity!   8)
2015 - Taylor 612ce first edition
2012 - Sigma 00M-15S
Thanks to Thalia, will definitely check them out.  They are beautiful!
Choice 1: Black with koa
Choice 2: Gold with abalone
Choice 3: Black with celtic
Thanks Josh  ;D, for all you do!
Huw1952
They look quality capos. Thanks for the giveaway. My choice would be:-
1 Dragon Abalone Inlay - very suitable for a Welshman!
2 Celtic Knot - again very suitable for a Welshman!!!
Thanks Huw
cc407
1 - Celtic Knot
2 - Dragon
George
Nice giveaway.  Please count me in.
1st choice - "Black Chrome Finish with Hawaiian Koa Celtic Knot Engraved Inlay"
(how could an Irishman not chose that one...)
2nd choice - "Black Chrome Finish with Hawaiian Koa Inlay"
Ptbcath
All of them are beautiful. First choice is dragon. Second choice is Celtic
Thanks
2015 Taylor 114e
scusu
Thanks! 1,2,3
2014 K26e
2013 Taylor BTO GA EIR/SIT
1980 Sigma DR-28
Thank you Josh, count me in.
1. Celtic
2. Koa
3. Dragon
Good luck to all
Guitar Cowboy
I'm In
1. Black Chrome Finish with Hawaiian Koa Inlay
2. Black Chrome  with Celtic Knot
Thank you!
(Mahogany/Urban Ash)
2016 GS mini-E Koa
Stringband Eric
    • My website
Okay. I'll join in.
1. Black chrome plain koa
2. Black chrome celtic knot.
Those look nice and I like the options for customizing fit to the guitar.
Eric P.
2018 Taylor GS Mini Koa
1997 Taylor 420-R
2013 Gibson J-35
packy
I'm in!  Thanks Thalia-Class Act!
1st choice - Plain Koa
2nd choice- Celtic Knot
Thanks Josh and good luck to all!
