Author Topic: ES2 setup  (Read 960 times)
Fletchpic
ES2 setup
« on: August 07, 2015, 01:08:48 AM »
Just curious how tight or loose most of us are adjusting the pickup hex-nuts. I basically tighten mine gently until it naturally stops, then I back off just a touch. (Less than 1/4 turn)
I've tried adjusting them according to the sound, but my amp is so small that it's easily overpowered. I once loosened them until one of the screws came out and it still sounded loud on my amp.
Also, it seems if you loosen them too much, the pickup can rather easily sink down revealing the holes in the bridge. Hmmm...
« Last Edit: August 07, 2015, 01:15:51 AM by Fletchpic »
Craig
    • UTGF Members Map.
Re: ES2 setup
« Reply #1 on: August 07, 2015, 10:00:34 AM »
There's a tech sheet or maybe a  video on the Taylor website showing you how to adjust then and I'm pretty sure there was a leaflet in the case came with mine.
1978 Music Man Sabre II
1980's Charvel Model 6
2014 816ce First Edition
2014 714ce FLTD Sassafras
2016 GS Mini e Koa
2017 Avalon A2-20c
And an Eastman Mandolin!
Visit the UTGF Members Map
