Author Topic: GS Mini neck change  (Read 2969 times)
phavriluk
GS Mini neck change
« on: February 24, 2014, 05:32:34 PM »
Seeing as Taylor products are so precisely manufactured, has anyone taken advantage of that characteristic and offered alternate necks for the GS Mini?  I'd love a 1 3/4" width at the nut neck, and seeing as the necks are bolted on and adjusted by shims, it seems technically possible to substitute an alternate neck rather easily.
Ted @ LA Guitar Sales
    • LA Guitar Sales
Re: GS Mini neck change
« Reply #1 on: February 24, 2014, 05:54:38 PM »
It would be possible if Taylor made a neck for the GS Mini with a 1-3/4" nut, but as of this writing they do not.
phavriluk
« Reply #2 on: February 24, 2014, 07:26:23 PM »
Ted, thanks for answering.  I was wondering aloud whether an aftermarket vendor could offer a 1 3/4" neck that would be bolt-on-interchangeable with the OEM Taylor neck, subject to shimming, seeing as Taylor precision-manufactures their guitars and appears to offer the possibility of interchangeable parts.  Or Taylor themselves, but it seems likely that they are not inclined to tool up for that.
« Reply #3 on: February 24, 2014, 10:02:05 PM »
from how i understand it, the various neck widths (1 11/16", 1 3/4" & 1 7/8" at the nut)
require different dimensions to be routed for the neck/fretboard extension pocket at
the heel block, so it may not  be as simple as purchasing another neck & swapping it out -
the cost to have another neck built, to rerout the neck pocket & setting up the guitar would
likely be more $ than what was originally invested in the guitar, if it was purchased new
it is possible to replace the nut with one that has 1 3/4" spaced slots & sanding the edges slightly -
this will not change the neck profile, but it will give a scoche more room between strings,
albeit at the expense of having the E & e a bit closer to the edge of the fretboard
phavriluk
« Reply #4 on: February 24, 2014, 10:26:51 PM »
Michael, thank you for explaining Taylor's configurations.  That helps explain the difficulty of making such a swap.  Oh, well.  I had considered the nut change you mentioned, but I'm not sure that I could manage the E strings' being closer to the fretboard edge.
dangrunloh
« Reply #5 on: February 28, 2014, 12:52:00 AM »
I was told at a road show that the upper bout of the Mini could not accommodate a 1-3/4 neck even if Taylor wanted to do it. A redesign of the body would be needed.  Of course this was the same person who told me the ES2 was just an experiment and not intended to replace the ES1.
