Author Topic: New Off Assembly Line vs New Old Stock?  (Read 6593 times)
Re: New Off Assembly Line vs New Old Stock?
« Reply #15 on: February 18, 2014, 11:16:48 AM »
While there is little scientific evidence of measurable improvement with before/after testing, we all "know" that guitars tend to open up.  You can argue whether perceived changes are "real" improvements, or simply comparisons between today and idealized (probably suspect) memories of what the tone used to be.  Do you REALLY remember exactly how this guitar sounded several years ago?  Can you see paint chips at Home Depot under store lighting and know for sure that it matches your kitchen wall?
My personal opinion is that both age and vibration help to mature or "open up" the tone.  Wood is essentially nature's composite material.  Man-made fiberglass is long glass fibers embedded in a polyester resin binder.  Wood is long cellulose fibers embedded in natural resin.  Over time the resin hardens or crystallizes, which changes the properties of the wood.  With movement and vibration, the fibers break loose microscopically from these resin attachments and therefore vibrate more freely, also changing the properties of the wood.  So both age and vibration are likely factors in the improvement.  Which one is more important?  Don't know.  It is hard to get one without the other.
The main question is:  Does the guitar sound good right now?  If so, it is a winner and most likely will only sound better in the future.  I would not worry too much about whether it is six months or six years old.
« Reply #16 on: February 18, 2014, 02:04:20 PM »
Whether it's a guitar's wood changing over time that alters its timbre, or the vibration it experiences over years of use, there are tonal differences perceived: this we can all agree on.  Here's the problem: how much of those "tonal differences" are due to our perception having changed?
"I know it's different, I can hear it ...today....."  hmmmm.....
:D
« Reply #17 on: February 18, 2014, 03:55:15 PM »
Quote
Quote
:D
I think the last two post are spot on.  My bet is that we can not remember precisely the tone of our guitars when it was brand new, to now 2 or 3 years later.  When things change slowly we don't notice the difference.  I have heard of people saying that one day they pick up the 1 year old guitar and it has suddenly opened up, I am a bit skeptical.  I do believe that the sound of a guitar changes over the years, after all it is wood.
krugjr
« Reply #18 on: February 18, 2014, 06:51:12 PM »
thanks again to all of you for your imput.....didn't think we'd go quite so deep, but it's fun......glad I asked UTGF instead of "Ask Bob"...instant information...theories, opinions, experiences, etc.....GREAT RESPONSES
Music.....the Universal Language!
Gary-N-LA
« Reply #19 on: February 19, 2014, 04:10:32 PM »
I've noticed exactly the same thing.  I can tell the guitar is adjusting to the room by how it goes out of tune after 15 minutes - often going sharp.  Once I make that adjustment, it settles in and doesn't go out of tune for a long time.
My guitars sound different from day to day. Maybe it's my perception and reception, or maybe it's the barometric pressure, humidity, etc. And often, they sound different after about 20 minutes of playing.
I've noticed a similar thing as well.  And have attributed it largely to the same things you have (my current mental state, level of fatigue, atmospheric conditions, etc.) -- as well as my inconsistent skills that I'm working to improve.
I've actually started doing something that I think mitigates some of the atmospheric effects of the 20-minute 'warm-up' period, though:  When I get home from work, I'll take mine out of the case and put it in the guitar stand of my playing area well before I plan to start playing (usually about an hour prior).  I'll prepare my dinner, sit down a bit to relax while I eat, then start practicing.  By then, the guitar has adjust to the prevailing atmospheric conditions.  So if it doesn't sound right, it's probably me...
2014 Santa Cruz 1929-00 - All Mahogany
2013 Taylor Custom GA - Cedar/Maple
2013 Martin Custom 00-21 - Sitka/EIR
2012 Cordoba C7 Classical - Cedar/EIR Lam.
2008 Fender Stratocaster 70s Reissue
gamblemad
« Reply #20 on: February 19, 2014, 04:43:46 PM »
I purchased a "New Old Stock" Big Baby..... I sent it back because it had some serious sound and physical problems.  I think it was dry....Very Dry.  The fretwires were unreasonably sharp, and it sounded really bad.  I can only explain the sound as harsh/unpleasant.  I have played with a few of the Big Baby's so I certain my description is accurate.  Make sure that you can return any "New Old Stock" you are looking at just in case there is an issue with it.
Jersey tuning
  • Quid Me Anxius Sum
« Reply #21 on: February 20, 2014, 04:21:25 PM »
Bought a new old stock 614--two years older than any other Taylor on the wall, and better sounding than the others (which ranged inclusively from 114-814 but were all current year models).  No current year 614 to compare it with at the time, so the impact of the wood type may skew this unscientific observation.
CURRENTLY PLAYING
'97 Tacoma PK-30 Sitka/koa
'05 TAYLOR 614ce
krugjr
« Reply #22 on: February 20, 2014, 07:38:27 PM »
as long as the NOS is kept in a "friendly environment", how many years it is stored doesn't seem to negatively affect the quality of said guitar.....that's pretty much what I'm hearing from the responses.....and whether a stored guitar "opens up" without being played is a debate that will continue for as long as music is played and songs are sung.....fun stuff.....oh, by the way, my most recent purchase (last month) a 2010 516ce CV NOS from Wildwood Guitars is absolutely awesome....Adirondack top and bracing, and for my heavy rhythm songs, it is the loudest and clearest tone I've heard, no matter how aggressively it is played.....I save my 514e-FLTD for the "pretty" songs (did I just say that?) and when I get after a heavy rhythmic song, out comes the 516.....I do prefer the light strings on the 514 and some of you suggested some brands of med-lights and I've already tried a couple and love them....little easier to the touch and they add that bit of brightness to my strummin'.....like some of you have said here, stick with a "good" store, with a return policy, and you can't go wrong.....Wildwood had to order "a bunch" of the addys in 2010 to get exclusive rights to market them, that's why the NOS.....they fit my style so well, if someone buys my gorgeous, perfect, mint (hint hint) 2009 855ce, I might just get a 514 CV too.....GAS attack coming on, I better excuse myself and head to the medicine cabinet for relief! Have a great day, my friends! Special thanks to michaelw.....
« Reply #23 on: February 20, 2014, 07:48:03 PM »
+1
even if it has hardly been played at all, provided humidity & temperature have been kept in check, a fresh set of strings,
a once-over to recheck neck relief & a fine-tooth comb just to make extra certain that the condition is still "as-new" & all's 8)
i forgot to note that those black ice .55 picks look to be of a jazz profile, rather than
a standard cut, but they're not tiny teardrop ones, so hopefully those will work for ya :)
dangrunloh
« Reply #24 on: February 28, 2014, 09:13:51 PM »
Quote
Quote
:D
My three year old Taylor 414 changed it's sound in less than 3 weeks time during a period of high humidity in early spring.  This was not not a case of fading perceptions or poor memory. The bass volume increased and the very high notes way up the neck on the solids got "sweeter" sounding, more silky.  I have played it every day since I bought it new. The change was so remarkable it caused me to write a post here wondering if my Taylor preferred a higher humidity than it's factory origins.  After being raked over the coals here for even suggesting it, I abandoned that theory. Someone even suggested I didn't really like the Taylor sound and actually preferred the muffled tone of a "wet" guitar.  To my delight the sound change stayed when it was dried out in a couple of weeks.
Something, some stiffness (like a glue joint) let loose inside that guitar that made it change fairly quickly.  I'm sure this isn't a normal occurrence but I'm VERY positive it happened.
I thought for a time that environmental changes of temperature and humidity could contribute to the opening of a guitar, but its also true I was playing it every day at least an hour, HARD, and had reached about 300 hours.
An argument against age alone comes from a 1987 Fender 260S solid top dread I owned for almost 20 years and never played because it always sounded brittle and shrill. It was never stored properly and was exposed to wide variations in temp and %RH.  It sounded awful in 1987 and it still sounded awful in 2006 when I began playing it. By 2010 after I had worn out the first 5 frets from playing it was a different guitar.
I'm a retired scientist and remain unconvinced it doesn't happen simply because some poorly conceived (or well conceived) experiment fails to produce a positive result.  Thanks anyway. Love my Taylor
« Reply #25 on: March 01, 2014, 04:33:17 PM »
I recall a Bob Taylor response in W&S about this a couple of years ago.  Paraphrasing, he said that the guitar will have three basic periods of noticeable "opening up" -- after the first couple of hours, after a couple of months, and maybe again after a couple of years.  The first one is likely a result of the glue and finishes achieving their final cure plus the wood settling into its new stressed condition as a guitar.  The second phase is likely due to some playing time.  The third phase is probably a combination of playing hours and aging, and possibly living through some cycles of temp and humidity.
« Reply #26 on: March 01, 2014, 05:07:06 PM »
the polyester finish & non-organic glues are pretty much cured once the guitar is being assembled -
some guitars may seem to be a bit "tight" or "focused" initially & there will be some acclimation from
different environments, such as the factory, while in transport, the dealer & the owner's residence,
but the frequency & duration of playing will likely have the most perceivable effect on tone, if any
over time, some of the hemicellulose in the wood dissipates, reducing the weight of the wood, not to be
confused with loss or lack of humidity & with further playing allow the guitar to vibrates more freely -
the "decay" of hemicellulose happens over time, whether the guitar is played or not, & provided the guitar has
been stored in a temperature & humidity controlled environment, after a few years a string change may be
needed & maybe a minor tweak of the truss rod, but it will probably sound a bit different than when it was built
