Author Topic: Cable query...TRS - XLR....  (Read 1221 times)
Thumb Picker
« on: August 04, 2012, 11:55:28 AM »
Reading the Taylor ES system brochure that came with my 714ce, I see where Taylor recommends using a balanced cable setup with TRS to guitar and  XLR to amp....pa etc...
My question is ;
Is Taylor referring to 42 v phantom powered XLR or power off XLR?
My gut tells me the correct choice would be the powered off XLR input since the ES system is already powered by the 9v battery.
However, I am a total novice when it comes to amp systems and cable hookups etc, since I've always played small venues where I was using either plain acoustic or into a mike.
I've just bought a Tascam DP-008 and want to record a little bit, so I'm now trying to get up to speed on
noise reduction, proper  cable connections ...etc
Thanks for your patience and input,
It's much appreciated!!
Hawk
« Last Edit: August 05, 2012, 03:49:43 PM by Fishhawk »
Taylor 614ce 1998 Quilted Maple beauty
Taylor 514ce-N
Taylor 312ce
Taylor 414ce Custom
Giraku
  • I play exclusively fingerstyle.
Re: Cable ...TRS - XLR....Probably a dumb query ...
« Reply #1 on: August 04, 2012, 02:09:32 PM »
Hi Hawk,
You are correct. ES system does not require phantom power.
‘18 Taylor K14ce Builder’s Edition (Koa / Torrefied Sitka Spruce)
'16 Taylor 514ce LTD (Granadillo / Cedar)
'16 Taylor K22e LTD (All Koa)
'15 Martin D41 Purple Martin #29 of 50 (Cocobolo / Adirondack Spruce)
Sound Clips are here.
