Author Topic: Any Taylor Twelve Strings In The House?  (Read 15773 times)
Re: Any Taylor Twelve Strings In The House?
« Reply #15 on: June 09, 2012, 04:17:34 PM »
Thanks Edward and everyone, I am beginning to lean towards a 356 or 656 for my 12-string purchase.
Tammany Tiger
« Reply #16 on: June 09, 2012, 10:30:04 PM »
I had no desire to own a 12-string for all the reasons mentioned ... that is, until I happened to play a Taylor GA3-12 at GC one day and it dispelled all my prejudices instantly!!
Still, I wasn't convinced that I wanted to spend that much on a 12-string, so I tried several lower priced makes and models.
In the end it came down to Taylor or the Seagull.  The Seagull Coastline Cedar 12 is a very, very nice instrument, especially for the money.  I am a huge fan of Seagull guitars, but, the Taylor was just in a league by itself.
And the fact that it has the NT neck while the Gull has a set neck, making neck adjustments easy on the the Taylor and all but impossible on the Seagull made me more confident that for the very long haul, the Taylor would serve better.
I respectfully disagree that neck adjustments are impossible on guitars with a set neck. Even set neck guitars have truss rods and the truss rod set up on the Seagull is one of the strongest around. Nor is it fair to say that a set neck may never be reset. That was going on for a time before bolt on necks came along. By the way, doesn't Seagull use a bolt on neck?
It seems to me that the legitimate point is that most twelve strings will require neck adjustments sooner than six strings do and that neck adjustments, particularly heel angle adjustments, will be easier on Taylors than on other guitars, particularly those with set necks.
I think we also disagree on Taylor 12s being in a league of their own. I actually thought that the tone of the entry level Taylor 12 was pretty comparable to the Seagull. Fit and finish were better on the Taylor and as you say the the NT neck makes the guitar maintenance easier. I agree that the Taylor is better but I am not sure that it is two and a half to three times better, using price as a measuring stick.
« Last Edit: June 10, 2012, 01:59:36 PM by Tammany Tiger »
Black Beauty
    • Black Beauty Music
« Reply #17 on: June 09, 2012, 11:46:13 PM »
Aww... I came in here expecting pics!
« Reply #18 on: June 10, 2012, 12:27:47 AM »
OK, so no affiliation here.  But I soincidentally ran into these from the AGF.  Nice ...especially the 854 IMHO!  (this should give you some satisfaction BB ;) )
http://www.acousticguitarforum.com/forums/showthread.php?t=251225
http://www.acousticguitarforum.com/forums/showthread.php?t=254563
Side note: the toughest thing about trying a Taylor 12 is the scarcity in showrooms ...let alone a GS-bodied 12.  Tone is the great variable, to be sure.  But rest assured a modern Taylor 12, particularly because of the NT neck, will play like no other 12 out there.
« Reply #19 on: June 10, 2012, 12:42:06 AM »
the seagull has a bolt on neck, not unlike a preNT Taylor, collings or goodall -
it's not a 'set-neck', where the neck heel & block are one (think Les Paul)
or a spanish heel (on some classical/flamenco guitars), dovetail or mortise & tenon
the truss rod adjustment allows for setting of the relief, not beck angle,
which i believe what was being referred to as the neck 'adjustment' &
on the seagull there would be a little more involved than what would be
required on a Taylor NT reset, but nowhere near what a dovetail 'entails'
if i were looking for a 12'er, it'd be a 356c (no need for e on this one, got enough of 'em) -
the 'snap' & 'punch' of sitka/sapele with the GS body shape just sounds extremely rich & full
(can't imagine what it'd sound like if the order of the octave strings was swapped, like a ric)
anyways, 650 hangin out here - square shoulder, more like a 'bird (yeah, it's a beast)
M19
« Reply #20 on: June 10, 2012, 06:33:55 AM »
I've got a couple of pix for you. BTW, this is the 655ce that Ed owned before the RT "took him home."
Oh, and I've lost 50 lbs since the following was taken!
Marty B.
Multi-Brand Owner
Tammany Tiger
« Reply #21 on: June 10, 2012, 07:10:14 AM »
Great stuff.
egkor
« Reply #22 on: June 10, 2012, 02:37:23 PM »
Recently at the Taylor Factory tour I was trying to help a potential new Taylor owner who was shopping for a 12-string.
He played a 656ce, then a 356ce (both GSs) while I listened at a bit of a distance.
They both sounded beautiful, of course.
But I did really like the 356ce, the sapele/sitka combo *really* works not only for the 6-string models but for the 12-stringers as well.
-Gary K
Martin- DX1 (2009)
Judson H
    • My Youtube music
« Reply #23 on: June 10, 2012, 03:27:11 PM »
Of course you can make truss rod adjustments, but I'm talking about actually re-setting the neck, which all 12-strings will need eventually.
I have a lot of recent experience with the issue of resetting the neck on a Seagull and this is what I have found out through talking both with guitar techs who work on them and the Godin/Seagull customer service reps.  I've also watched Seagull guitars being made and seen how the necks are attached.  Here's a Youtube of the Seagull Factory Tour that shows the process in detail:  http://www.youtube.com/watch?v=fXGV31hOYhs
Seagulls, for the past 4-5 years have used a process by which the neck is permanently set in epoxy.  It's a very precise process, but it precludes being able to do a traditional neck re-set down the road.  The bolts on a Seagull neck are only used to hold the neck in place while the epoxy is setting up, then although they are still in there, they become superfluous.  While you can achieve the same results as a neck re-set, you have to shave down the bridge on a Seagull if it needs a neck re-set.
I fully agree that the Taylor is definitely not three times as good a 12-string as the Seagull is ... but IMO it's better by a fair measure and the supreiority is reflected in the price.
And I'm a guy who thinks so highly of Seagull guitars that I run a chat forum with 200 members devoted specifically to Seagull/Godin owners and fans.
I love Seagulls and over the past few years I've owned 4 of them.  Seagulls are great guitars ... especially for the money.
« Last Edit: June 10, 2012, 03:37:41 PM by Blackville »
2012 Taylor GA3
2012 Martin D-18
2004 Seagull Artist Mosaic QII
2001 Simon & Patrick Cedar Folk
1967 Silvertone Sovereign 1220 Jumbo (my high school guitar)
Fishman Loudbox Mini and Shure SM58
Judson H
    • My Youtube music
« Reply #24 on: June 10, 2012, 03:30:25 PM »
Michael ... that was true up until about 2006 ... after that, all Seagull necks have been permanently epoxied in place, with the bolts serving the purpose of securing the neck while the epoxy sets.  According to Seagull customer service and my guitar tech, newer Seagulls necks cannot be re-set, but you can shave the bridge down to achieve the same results.
This Seagull Factory Tour Youtube shows the process in detail:
« Last Edit: June 11, 2012, 10:14:06 AM by Blackville »
2012 Taylor GA3
2012 Martin D-18
« Reply #25 on: June 10, 2012, 05:01:52 PM »
seagull must have under gone other changes too (body depth & so on) -
the neck can be reset, but it all depends if
one desires to put the resources into it
Tammany Tiger
« Reply #26 on: June 10, 2012, 06:13:40 PM »
According to Godin, as reported in an Acoustic Guitar Magazine blog, new Godin necks cannot be reset:
Just got a reply from Michel Belanger at Godin and my 2005 Artist model has the older neck that is simply bolted on and CAN be re-set ... the epoxied neck process began in 2006 ... this is good news for me, but I do agree with the comment made by RLV, that the higher-end models should be made in such a way that they can be adjusted.  Michel confirmed to me by e-mail today that the newer Seagulls with the epoxied necks are indeed fully covered under warranty, so that's comforting for original owners.  Either Godin is correct in their theory that these necks will not need re-set ... or they are going to be replacing a fair number of guitars under lifetime warranty for original owners.  It's the people who buy them second-hand who may suffer, however.
http://www.acousticguitarcommunity.com/group/SeagullAficionados/forum/topics/seagull-neck-re-sets-what-i-found-out-today
My own experience with wood epoxies supports this conclusion. The adhesion bond will not break and the glued part always comes loose with hunks from the piece to which it is glued. That's part of what makes hide glue desirable in instrument construction. It's fussier and not as strong but it dissolves in water.
e8n
« Reply #27 on: June 10, 2012, 07:22:59 PM »
I've got an all 'hog BTO that I bought used from Jim.  Love it when I get to play it.  My wife has pretty much made it hers to play church gigs with.  Very nice guitar.  When looking at it I played it against an 400 series 12 string (very unimpressive) and a Koa 12 (awesome guitar that I regret not buying almost every day).
-Dave
2011 Taylor Custom GS (Adi/Rosewood)
2012 Taylor 814LTD Spring Limited
2008 Fender Telecaster
2010 Kentucky Mandolin
Guitars of the past: Alvarez AD60, 2007 Taylor 110ce, 2006 Taylor 710ce, Taylor 2008 GS Fall Ltd, 2010 Taylor 814ce, 2010 Taylor K26c,2010 Taylor Custom DN, Taylor 714ce
Judson H
    • My Youtube music
« Reply #28 on: June 10, 2012, 07:39:31 PM »
Yup ... But in the interest of full disclosure, that's actually my web page and my quote discussing my Seagull Artist Mosaic  (small world, the internet)  ;)... but your subsequent conclusion concerning the feasibility of trying to remove and re-set an epoxied neck is exactly what I've been told numerous times by both Godin and luthiers.  It just won't work and is not worth the trouble.
But, I suppose MichaelW is technically correct ... anything can be accomplished if the the time, effort, and resources are applied .. but it's just not feasible to do that with a Seagull.
PS:  Sorry for the thread jack ... it was never supposed to wander off into a technical discussion of Seagulls here on the Taylor Forum, LOL.
« Last Edit: June 11, 2012, 10:16:44 AM by Blackville »
2012 Taylor GA3
2012 Martin D-18
« Reply #29 on: June 10, 2012, 08:10:16 PM »
Hey Marty!!!   Ahhh, the pic brings back fond memories.  Lookin good with the guit, man!  Enjoy, my friend!!  :)
Ed
