Author Topic: LKSM  (Read 3013 times)
lutehole
LKSM
« on: June 02, 2012, 04:42:45 PM »
Does the LKSM come with light strings or medium strings?
If i choose to use light gauge strings will i need to change the nut?(i assume it is cut for the stock medium strings)
Re: LKSM
« Reply #1 on: June 02, 2012, 06:13:04 PM »
the LKSM is designed to be tuned down to C# & it uses a 'custom gauge' set
LKSM                 .013        .017         .030         .038       .047        .056
                         .013        .017        .014        .018      .026        .035
one way of getting the strings needed (having to buy 2 more & having * 8 left over)
11152      12 Light      * .010      * .014      * .023        .030      .039 (.001 off)     .047
                                  * .010        .014      * .009          * .012      .018             * .027
11102      Medium           .013        .017        .026        .035         * .045        .056
plus                                 ,013        .017
another way (buying 3 more plain strings & having * 3 strings left)
11002      Extra Light      * .010        .014      * .023        .030      .039 (.001 off)     .047
plus                                  .013        .017        .018
comparing the custom set to conventional 12
11152                      .010        .014        .023        .030      .039        .047
                           .010        .014        .009        .012      .018        .027
you should  probably be ok for the most part -
the .003 - .009 differences shouldn't  necessitate the expense of having the nut replaced
  • Northern California
Re: LKSM
« Reply #2 on: June 02, 2012, 06:57:28 PM »
I give up.  What is an "LKSM"??
Re: LKSM
« Reply #3 on: June 02, 2012, 07:10:52 PM »
Leo Kottke Signature Model 12-string guitar made with mahogany / sitka and no fretboard inlays
Here is a picture of the  6-string version which is looks exactly the same except for the number of strings:
« Last Edit: June 02, 2012, 07:50:49 PM by Herb Hunter »
Re: LKSM
« Reply #4 on: June 02, 2012, 07:16:59 PM »
****highjack**** I am going to see Leo Kottke next week.......
Re: LKSM
« Reply #5 on: June 03, 2012, 12:57:26 AM »
here's an unofficial string set
lutehole
Re: LKSM
« Reply #6 on: June 03, 2012, 05:14:23 AM »
What I meant to ask is if I can use lights on it wout damaging the nut/wearing it out in the wrong way
Re: LKSM
« Reply #7 on: June 03, 2012, 12:43:22 PM »
the nut slots have already been cut for the heavier gauge strings, but a light gauge set
(.010 -.047s) tuned to concert pitch  should  not 'damage' anything or require having the
nut replaced, unless there is a buzz, due to one (or more) of the nut slots being a bit too low
the only way to find out is to try it - you won't hurt anything by merely changing strings
lutehole
Re: LKSM
« Reply #8 on: June 03, 2012, 05:14:11 PM »
Thanks Michael.
That's my concern, the buzzing or uneven wearing of the nut due to use of light strings; I won't be using the stock strings since elixir don't sell a set.
I have no experience w this sort of thing and hence my question; will there be uneven wearing or buzz from the use of lights
Re: LKSM
« Reply #9 on: June 04, 2012, 01:10:09 AM »
if the nut is in good condition (with the nut slots cut to the correct depth & not excessively worn), using a .010 - .047 set
tuned to concert pitch (A 440Hz) should  be fine, as the overall tension for both sets is nearly the same (256 C# vs 249)
not darth
  • Near the lake in Minnesota.
Re: LKSM
« Reply #10 on: June 04, 2012, 07:31:47 PM »
Cool, you'll enjoy it!  My wife and I went to see LK last fall in Red Wing, MN.  Was a great show, I really enjoyed the storytelling he did between songs.  A very very fast fingerpicker, wish I could play a tenth as good.
-K
Member #34
I'm not darth.
Re: LKSM
« Reply #11 on: June 04, 2012, 07:55:04 PM »
Leo is one player I have been able to go see yet.  I sure would like to.  I wonder what the story is with him and Taylor, how did he come to play Taylor?
