Author Topic: Clear Pickguard Material For Satin Finishes or Other Options  (Read 3266 times)
« on: March 24, 2012, 12:52:43 PM »
I'm looking for a peel-n-stick, clear pick guard for another instrument (non-Taylor, sorry), but like the one that Taylor offers.  In the little bit of checking I've done, that material only works on glossy finishes.  Even Taylor's is for glossy finishes. My instrument has a satin finish. Also, I'd like to get a sheet of it, because I'll have to shape my own.  Does anyone know about a clear material that can be used on satin finishes?
I guess I'd be open to other options that anyone would have to offer, too. Thanks.
Re: Clear Pickguard Material For Satin Finishes or Other Options
« Reply #2 on: March 24, 2012, 05:22:33 PM »
hi TG,
i don't know of the exact material used (name or type), but
Alvarez has a transparent satin pickguard on the dy62c
http://www.hydroponicsonline.com/store/Alvarez-Yairi-DY62C-Burled-Mahogany-A-E-Cutaway--Hardshell-Case-No-reserve_130582404673.html
contacting either st louis music (u.s. distributor for alvarez)
http://www.stlouismusic.com/
or alvarez may help for more information
http://www.alvarezguitars.com/
larrivee used to have a transparent satin pickguard on their 03 series,
but they have since changed to a more traditional looking pickguard
lmii has sheet of pickguard material (i'm not sure is the clear material is glossy) &
if you happen to find the material you like elsewhere & if it does not already
have an adhesive backing applied to it, they have sheets of adhesive film
http://www.lmii.com/CartTwo/Secondproducthead.asp?CategoryName=Pickguard+Material
stewmac also has pickguard material, but the mylar is likely glossy
http://www.stewmac.com/Shopping?actn=search&keyword=pickguard+material
vinyl pickguards will potentially interact with nitrocellulose finishes &
screen protectors are made of a very thin  film  (most are glossy) -
working the air bubbles out of silicone adhesive would be a job, imho
also, that screen protector shows to have a 'silicone adhesive coating' &
even though it states no glue residue when removed, i've heard that
silicone migrates & if any finish work is needed to be done a guitar
with a poly finish, any traces of silicone will make it very difficult to do
