Author Topic: Taylor 814ce ES2 Pickup System  (Read 11738 times)
Ade
« on: February 16, 2024, 03:56:09 AM »
Hello
I read some Statement about the problems with ES2 Pickup System. I have two Taylor Guitars 814CE Manufacture Date 2021 and 214DLX Manufacture Date 2021. The acoustic sound from both Guitars are beautiful but the Pickup System ist very bad. I try all options with EQ and use a Di-Box. The result is now and is importend frequence about 3.5Khz turn to low. Also 40HZ to low. It is now a little bit  better result but not good. The Guitars are very expensive but the Pickupsystem is terrible and the Sound is tinny. Have anybody a good idea. Sorry for my bad english but my home Country is Bavarian in Germany.
Thanks and kind regards
Ade
« Last Edit: February 16, 2024, 03:59:54 AM by Ade »
Taylor 814CE 2021
Taylor 214CE 2021
Fender Stratocaster 5ea
Fender Telecaster 1ea
Gibson Les Paul Custom Black Beauty Mod.57er, 3 Pickup
and many more, my wife says to much.
PaulWood
Re: Taylor 814ce ES2 Pickup System
« Reply #1 on: February 16, 2024, 11:13:42 AM »
Hello Ade.
You will find you are not alone in your opinion of the ES2 system. There are a number of threads on this subject, which you may want to check out. To be fair, some people love ES2, but not me!
My first Taylor was a 2006 614ce, which was my favourite guitar for a long time. It was originally fitted with the first ES system, which was very good. When that system needed replacing, I was told that I had to have ES2 as the replacement. This was done in Amsterdam. I think that was about 10 years ago, and the sound was so bad that the guitar has not been played more than a few times since. Recently, after I'd had some advice on EQ settings from a Forum member, I decided to give the guitar another try. I found it is now almost acceptable BUT the slightest touch of my fingers on the scratch plate, or the bodywork, is amplified so much that it interferes with the music itself and I would find it impossible to perform with it. I may have to have a non-Taylor pickup fitted.
Hopefully, you'll get a few helpful replies to your question, but I advise you to look at the existing threads.
Good luck!
« Reply #2 on: February 16, 2024, 08:07:07 PM »
Guten abend und willkommen, Ade.  I have no direct experience with ES2 mostly because of these stories and how consistently they appear.    Kudos to anyone who has successfully used an ES2 system, but they seem to be in the minority.
I'm quite happy with ES1.3 in several of my former Taylor guitars and the one remaining koa 424.  But ES2 is a major barrier to purchasing anything new.  I'd rather get a guitar without electronics and then add the system of my choice, rather than default to something that is (being blunt) "...not ready for prime time....".
« Reply #3 on: February 16, 2024, 09:51:28 PM »
Hi there Ade,
Welcome, glad to have you here!
Are you plugging into a mixer then to PA speakers, or into a guitar amplifier?  I hope the PA as that will get you the best results.
With the ES2, if you have a parametric or graphic EQ, try these approximate frequency values:
- 400-500Hz: decrease
- 900Hz-1.2khz: decrease
Leave all other frequencies "flat" (unchanged), and judge: is this any closer or better sounding so far? (for the first step).  I have found that reducing in these frequency ranges tends to "clear up" the ES2's muddy low end, lending some overall clarity just by subtracting these "boomy" tones.
If the above gets your tone closer to your preference, now play around with adding/subtracting the upper-midrange frequencies (2kHz-3kHz) and the treble (4-6kHz).  Adding or subtracting in these frequency ranges will affect the brightness and clarity of your tone: too much in one direction will result in dark, dull voice or an overly bright and thin voice.
Tell us what you get.  :)
Ade
« Reply #4 on: February 18, 2024, 01:44:05 PM »
Hi
i have read other Threats about ES2 System and i know i not alone with the same problem.
I try many positions on EQ and also from Edward recommend 400 - 500 decrease and 900 - 1.2 khz decrease. It is a good recommend. I used a 10 Band EQ. Only my Mixer Dynacord PM 1000 with parametric Mid is now so i mean and listen Hi turn a little less, mid by 500hz more less and Bass a little bit more. Further use the Button for cut 80hz and voice filter. I get now a easy acceptable result. PA Box is a EV 15/3.
Many Thanks on all Taylor Friends.
Ade
Taylor 814CE 2021
Taylor 214CE 2021
« Reply #5 on: February 18, 2024, 09:45:12 PM »
Hi Ade,
I'm glad your tone is getting closer to what you like!  The bass cut at 80Hz is good (I assume is a HPF on the mixer), and if you want more "tight" bass you can still use the HPF at 80Hz and boost a little bit at 100Hz for a "focused" low end that still keeps the guitar's voice clear.
Every mixer/PA is a bit different so continue to experiment with mild boosts and cuts, but most of the time, cutting frequencies is much better than boosting.  Glad your ES2 is sounding better!  Personally, while the ES2 is certainly not my favorite system, I find I can get it to sound fairly good live. :)
Ade
« Reply #6 on: February 23, 2024, 03:06:23 AM »
Hi
The important step was I turn on the Pickup 3 Inpuss screws on sattle all return to low contact. And turn all 3 Pickups into same loudness. I a little difficult. The Bass Strings E and A had bevor to much Pickup Feedback.
It is now a little quitter but i get now a acceptable result. PA Box is a EV 15/3.
Ade,  from Bavarian
« Last Edit: February 23, 2024, 03:08:19 AM by Ade »
Taylor 814CE 2021
Taylor 214CE 2021
nickcapfl
« Reply #7 on: April 22, 2024, 10:38:48 AM »
I have 3 Taylors with the ES-2 system and struggle with all of them. I have a more percussive style of playing and I always use a pick and found that the ES-2 picks up not only noise from my pick, but also from my finger nails and palm, a screechy noise.
For my 814ce, I found that it worked best when I loosened the middle pickup bringing its volume down to match or be slightly below the bass and treble pickups.  Leveling the pickups really helped to reduce the noise I was getting and allowed me to fix the rest with the EQ.  I agree with the EQ settings others have recommended for my 814ce.
I was not so lucky with my GS Mini or my 562ce 12-string.  I do not think that the ES-2 works well for short scale guitars.  I just could not beat the noise, even with adjustments.  For these guitars, I worked with Taylor and they sent me an UST to replace the ES-2 transducers.  The UST worked perfectly with the ES-t eq that was already installed in the guitars.  I just left the ES-2 in the holes so both options are available and the only modification was the small hole for the UST.
I am now finally happy with the plugged in sounds from my GS Mini and my 562ce.  I have left the ES-2 in my 814ce for now, but may convert it to UST in the future.
« Reply #8 on: April 22, 2024, 12:41:19 PM »
Nick, I'm glad that Taylor took care of you and sent a functional replacement pickup that works.  This is the first time I've heard about potential issues with shorter scale guitars.  That is interesting.
I've made no secret of being totally underwhelmed with ES2 in every way.  But they simply cannot admit that it isn't working well for most of us.  I will not buy any Taylor guitar, new or used, if it has ES2.  (I know that you CAN order without pickups, but I prefer to play before pay).  And I always caution folks that send their instrument back to the mothership for repairs.  No matter how hard they try to upsell the "upgrade", absolutely DON'T let them replace your existing pickup with ES2 while they have it.
« Reply #9 on: April 23, 2024, 12:41:35 PM »
I've said it many times --perhaps too many-- that I can EQ the ES2 on my dred to sound decent live, but it will never be a choice of mine, ever.  For me, it is ES1.3 first, then ES1.2 is acceptable.  Beyond that, I'd rather have a Taylor without any system, and merely pop in the Baggs pickup of my choice.
But these ES1 guitars are narrow-model-year choices which limits me quite a bit.  Which is all the more reason I stick with what I got (and am uber-thankful for them), and by and large "done" with any other acoustic purchase unlesssss I see something that ultimately checks all the right boxes for me. Sorry as that was a bit OT, but heck, it's a slow morning! :)
PaulWood
« Reply #10 on: April 25, 2024, 07:48:14 AM »
Don't be apologising Edward - it's a subject which causes hypertension globally I imagine - it certainly does here in the UK!
I'm ok with 1.3 - it certainly provides me with an acceptable sound on 3 of my Taylors, although, if I'm totally honest, they all have issues of one sort or another. Minor when compared to the ES2 issues, so I've learned to live with them (I suppose that in itself is pretty darning for a premium guitar manufacturer?)
I'm guessing Taylor will continue to bury their heads in the sand on this - too much invested in ES2 to back down, it seems. They clearly don't think it's a major issue, but it might be - there's plenty of competition out there and a growing number of disenchanted ex-Taylor fans.
Perhaps they should do with pups what they've recently done with strings?
I've recently posted (again!) my dissatisfaction with ES2 on my 614ce. In spite of Edward's really helpful EQ advice (which resulted in an almost acceptable tone) I couldn't play the guitar on recordings or in any live situation (which, thankfully, I do very little of nowadays) due to the interference of noise transmitted through the top by the slightest finger contact. I note that one respondent on this thread has mentioned that as an issue but there must be loads of Taylor owners out there that have encountered it. If so, let the Group know by replying now. The more comments we get at this level the more likely Taylor are to sit up and take notice.
BTW I'm a bit of a dinosaur and wish I could get the original ES back - AA batteries and all!
« Reply #11 on: April 25, 2024, 06:30:38 PM »
Agreed.  I was OK with ES1.2 in my 2006 GS-K (aka K16) and the ES1.3 with 9V battery was an incremental improvement in my other guitars.  Either worked perfectly fine for my needs, with ES1.3 was definitely the pinnacle, IMO.  Apparently Taylor does not care about alienating their long time customers.   ???  I have no illusion that they will voluntarily abandon ES2 anytime soon, so I'm out of the market.
Ade
« Reply #12 on: February 06, 2025, 05:37:39 AM »
Hallo
Es ist nun schon einige Zeit vergangen und habe mich so halbwegs mit meinen Taylor ES2 System arrangiert aber letztendlich bin doch nicht mit dem Sound glücklich geworden.
Habe immer wieder Versuche gestartet um den Sound des Pickups zu verbessern.
Habe nun in meine 214ce DLX einen anderen Pickup eingebaut da ich mit dieser Gitarre auf der Bühne benutze.
Es ist ein Replacement System ES2 von Go Acustic Audio. Es ist nicht Billig aber es hat sich für mich gelohnt da ich nun endlich den erhofften Typischen Sound einer Westerngitarre. Hatte nun doch schon einige Gespräche mit anderen Taylor Gitarristen die überwiegend das gleiche Problem des Sound klagten. Warum Taylor hier auf diese doch große Anzahl der ES2 Probleme nicht reagiert ist mir ein Rätsel. Man sollte doch den Kunden zufrieden stellen aber eine Veränderung des ES2 Systems zum besseren habe ich noch nicht gesehen aber wie man weiß ist das Gehör bei jeden Menschen ja anders.
Habe noch eine 814ce und eventuell wechsle ich auch den Pickup damit ich diese auch mit auf der Bühne verwenden kann und der Sound auch gut ist.
Ade
« Last Edit: February 06, 2025, 05:41:45 AM by Ade »
Taylor 814CE 2021
Taylor 214CE 2021
SDTaylorman
« Reply #13 on: February 06, 2025, 01:37:11 PM »
Hallo
Ade
Per Google translate (I hope that's OK / Ich hoffe das ist okay):
Hello
Some time has passed now and I have come to terms with my Taylor ES2 system but ultimately I was not happy with the sound.
I have tried again and again to improve the sound of the pickup.
I have now installed a different pickup in my 214ce DLX because I use it on stage with this guitar.
It is a Replacement System ES2 from Go Acustic Audio. It is not cheap but it was worth it for me because I now finally have the typical sound of a western guitar that I was hoping for. I have already had a few conversations with other Taylor guitarists who mostly complained about the same problem with the sound. Why Taylor does not react to this large number of ES2 problems is a mystery to me. You should keep the customer happy but I have not yet seen a change to the ES2 system for the better but as we know, everyone's hearing is different.
I still have an 814ce and I may also change the pickup so that I can use it on stage and the sound is good too.
Ade
