Author Topic: Techniques for Breaking in a New Taylor Guitar  (Read 6255 times)
pickingthru
Re: Techniques for Breaking in a New Taylor Guitar
« Reply #15 on: November 22, 2021, 08:24:54 AM »
Keep it out of its case and play it daily.
OR...keep it in the case (and protected) but play it daily (multiple times per day if you can). That 22 seconds to open the case and take out the guitar will be paid back in spades in keeping your guitar in great condition when you're not opening it up.  ;)
Spot on!!!  Play it.  Play it a lot.  It will sound better and better.  But you have to play it.
McPherson Sable
Martin 000-16
Former 314ce owner
wisedennis
« Reply #16 on: December 05, 2021, 08:49:16 AM »
Definitely strumming hard with * medium gauge (013-056) strings would help the guitar to open up
Medium gauge has more mass so it creates more momentum and vibrations to the guitar.
IMHO
wisedennis
« Reply #17 on: December 05, 2021, 08:54:05 AM »
This is a quote from legendary guitar luthier Ervin Somogyi,
 “””TONAL POTENTIAL AND TONE CHANGES OVER TIME
It is common knowledge that wooden string instruments — whether they be pianos, mandolins, lutes, or guitars — benefit from being “played in”. Older instruments have tonal qualities of mellowness and smoothness that newer ones lack, the latter often sounding somewhat brittle and harsh in comparison. The analogy of making a stew is often used to describe the quality of transition of a sound which is initially a bit rough, “green” and unsubtle but which gradually blends its elements into something more integrated and smoothly pleasing. In the guitar, also, different woods take different amounts of time for getting “played in”. Why this is so is not fully known but, obviously, it has to do with changes in the cellular and fibrous structures of the woods over time.
Some of these changes have to do with the adaptation of the woods to the stresses of being strung, after possibly centuries of being unencumbered by such forces. A main physical indicator of these changes is seen in the doming in the area behind the bridge which almost all older guitar tops show, but which new ones won’t yet have. Extreme distortion is problematic, but a merely visible amount of it is absolutely normal and even desirable; in fact, guitars which are so overbuilt (through thicknessing, doming, bracing, etc.) or understrung that this distortion of the wood is prevented will never manage to have the developed sound every player wants. The act of actually playing on a guitar, over and above simply stringing and stressing it, seems to have a decisive and accelerating effect on this blending; as with muscles, stretching and “warming up” seems to loosen things up significantly. I make my guitars yielding enough to have some top pull-up, and tell my clients to play them a lot for at least the first few weeks.
Finally, all of the woods described above have a certain tonal potential rather than a fixed quantity of tone. That is, they can be worked with to enhance or suppress certain portions of their potential response spectrum. However, like a plank of wood that can only yield usable pieces shorter than itself when it is cut, and never a longer piece, guitar making woods benefit from the outset only in having the most and best potential tone for their intended use. You can work with any wood to make it sound a lot worse than its potential; but you can only work with it to make it a little, if any, better. Once you’ve figured out what you want your next guitar to sound like, go out and buy the best wood you can find for it.“””
donlyn
  • De gustibus non disputandum
« Reply #18 on: December 05, 2021, 04:03:36 PM »
Just trying to keep it simple, here it is:
I don't worry about whether or not a guitar will 'break in' at some point, because I liked/like the sound of all my guitars as is, otherwise they would never have made the trip home with me. While I don't have a set schedule on this, all of my guitars are available to be played at any point in time, especially on 'watering' (Oasis humidifier tube) days.
The biggest thing is getting used to subtle (and sometimes not so subtle) differences in playing each one. The newest has always had a 'honeymoon' period while it breaks me in. The latest I got about six months ago (solid-wood spruce/maple Epiphone IBG J-200 Jumbo) and it still gets the Lion's share of my playing time. And that's mostly because I like to play it so much. And it's been a few years since the last 'latest' (a Taylor) one. (My signature is also my acquisition order, 1-4 and the last new, the others used, combined.)
So not having to worry if the guitar will ever break in, I just let it do it's thing naturally. I do have a 35+ year old bought-new Gibson spruce/rosewood J-200 Jumbo and it sounds terrific and always has. I treat it like it's a brand new guitar, play it 'cause I like it, and wonder at it's current sound. I guess you could say I've been breaking it in for all these years, and it's now also got a wonderful patina to the spruce top.
Two more quick notes. I currently favor using Elixir PB HD Lights on most of my six string guitars and fingerpick all of my instruments using my nails as picks.
Be well,
Don
« Last Edit: December 05, 2021, 04:26:40 PM by donlyn »
* The Heard:
09 Taylor  all walnut Jumbo
* Tenor Ukuleles:
Kala KA STG
Kala KA APT5 CTG 5 string
DenverSteve
« Reply #19 on: January 14, 2022, 10:24:19 AM »
I'll distill it even simpler.  Buy a guitar you enjoy and play it. The more you play it, the more you will like it. Do the above and it won't matter if it changes or not. Now strings is a whole different thread.
DimEyeGuitarGuy
« Reply #20 on: March 07, 2022, 04:15:08 PM »
Just play it. It’ll be what it’ll be. My 914ce LTD w/ Bocote is about 6 weeks old now. It sounds fantastic to me. It gets played for hours a day. If that changes something that makes it sweeter over time, then fine. But I won’t be worrying/wishing over it. I love it now.
Tom (DEGG)
___________________________
2021 Taylor 914CE LTD Bocote
donlyn
« Reply #21 on: March 14, 2022, 11:50:57 PM »
Exactly.
Just play it because you know it deserves it.
Otherwise you wouldn't have acquired it in the first place.
Don
* The Heard:
* Tenor Ukuleles:
Kala KA STG
