Author Topic: Going Wireless?  (Read 1271 times)
BrianNY
Going Wireless?
« on: June 05, 2020, 06:23:46 PM »
I'm intrigued by the wireless systems that now seem to be available from many manufacturers and am interested in trying one out in order to help reduce my tangle of cords and allow for more freedom to wander around as I play.  My setup is a Taylor GA with ES2 going into a Carvin AG300 amp, sometimes with a TC 'harmony singer' pedal in the middle.  So the transmitter would go into the guitar, and the receiver either into the amp or pedal, depending on whether I'm using the pedal that day.
Are folks with an ES2 having success with a particular brand and model of wireless transmitter?  (Note: some of them say they are not recommended for 'active' guitars which I imagine would exclude an ES2 from those since it has a battery preamp in the chain.)  Also, I'm hoping to not have to spend a fortune to get good results.  What has been your experience and which would you suggest?  Thanks!
Marty C
Re: Going Wireless?
« Reply #1 on: June 05, 2020, 08:01:55 PM »
Hi Brian,
I am currently using the Xvive U2 with good success.  I am sending the signal to my TC Helicon Harmony G or TC Helicon Play Acoustic.  The harmonies track well and the guitar sound is the same as a good cable (from my ears).  I have a Taylor 814ce deluxe with the ES2.  The signal eventually winds up in a Bose S1 Pro.
Please let me know if I can Answer any other questions.
BrianNY
Re: Going Wireless?
« Reply #2 on: June 06, 2020, 05:20:37 AM »
Thanks Marty C!
Tinker Taylor
Re: Going Wireless?
« Reply #3 on: June 12, 2020, 06:00:32 PM »
I used the XVive U2 with my Telecaster and it worked perfectly - home use only. Weirdly, I found I preferred hard wiring, so I went back to a lead. No logical reason for it - don't even know why myself... maybe because I just like the look of those Fender tweed cables.
