Author Topic: How does the GS mini KOA sound compared to other GS mini's?  (Read 2122 times)
marc55
« on: September 01, 2017, 01:46:42 PM »
Is the sound better?
Thank you
M
2017 Taylor Roadshow GS Mini AA-KOA, Ltd
2014 Collings Baby- Flamed Maple
1973 Guild D55
Minnesotaman
Re: How does the GS mini KOA sound compared to other GS mini's?
« Reply #1 on: September 01, 2017, 05:38:45 PM »
That would be in the ears of the beholder. A little like how high is up. ;)
« Reply #2 on: September 01, 2017, 08:37:45 PM »
It depends on what you like to hear. Hardwood tops like koa or mahogany tend to sound warmer or more mellow than spruce tops, which typically have more sparkle on the high end.
Dulcilo
« Reply #3 on: September 06, 2017, 09:14:43 PM »
Many will say the tone wood does not make much difference in a laminate guitar. There is a subtle difference because of the top wood, though. My all koa  mini is a bit more mellow than the rosewood version I had, but not as warm as the all mahogany versions I have tried out.
Guitarsan
  • Keep calm and play on!
« Reply #4 on: September 16, 2017, 12:51:00 AM »
All should say the laminate sides and back make no difference despite which tonewood veneer is used.
What does make a difference is the solid top wood.
So a spruce/(laminate)sapele should sound the same as a spruce/(laminate)walnut, but a spruce/(laminate)walnut will sound different than a koa/(laminate)koa. But only because the difference between spruce and koa tops in the latter case.
« Reply #5 on: September 16, 2017, 10:00:13 PM »
How high is up?  Well, it is as high as my drill Sarg. said it is.
