Author Topic: Hi from SD  (Read 1482 times)
Lardog
Hi from SD
« on: May 09, 2017, 04:28:49 PM »
Hi All.  Another acoustic guitar affectionado from Sun Diego.  I have this 12 string but can't find any serial number/model number on it.  Any ideas?
Re: Hi from SD
« Reply #1 on: May 09, 2017, 05:27:27 PM »
Welcome. As close as you are to Taylor, have you taken it there to get information on it?
cotten
Re: Hi from SD
« Reply #2 on: May 09, 2017, 09:29:00 PM »
Have you looked inside, up on the neck block? If a label is not there, then by all means, Taylor Guitars should be your next stop. Mind showing us the back and sides?
cotten
Soli Deo Gloria
NavyChap
Re: Hi from SD
« Reply #3 on: May 10, 2017, 11:21:20 AM »
Lardog, welcome aboard -- I absolutely LOVE Sn Diego -- was stationed in El Toro when on active duty.
2015 Taylor 314ce
1997 Taylor 414ce
2005 Zager ZAD50CE
2016 Seagull S6 Original
2016 Epiphone PR-5E/N
Lardog
Re: Hi from SD
« Reply #4 on: May 17, 2017, 07:15:05 PM »
Thanks for the welcomes.    Yea SD is hard to beat.   Though it's getting crowded and housing is pretttyy high.    Here are some more amatuer pics of the guitar.
timfitz63
Re: Hi from SD
« Reply #5 on: May 18, 2017, 09:42:49 AM »
Welcome!  From your latest photos, I'd venture the guess it's an older 555.  It definitely looks like a Jumbo body to me; the wood on the back/sides is either Sapele or Mahogany, and with the gloss finish I'm going to go with the latter.  So probably a 555.
Serial number is going to be on the label.  As suggested by "cotten," the label on older Taylors was tucked up inside the body, where the base of the neck joins it.  If it's missing, I'm not sure how that can be rectified, or whether Taylor can help to identify it in some other way so they can supply a replacement label.
T5: C1, C5-12, S (Aztec Gold)
Lardog
Re: Hi from SD
« Reply #6 on: May 18, 2017, 09:56:26 AM »
Thanks for info!  I probably just can't see the number up there because of the pickup.
Looks like this one:  http://www.acousticguitarforum.com/forums/showthread.php?t=435683
Think I can get $xx for it?
Per forum rules.
« Last Edit: May 18, 2017, 09:59:37 AM by TaylorGirl »
Lardog
Re: Hi from SD
« Reply #7 on: May 24, 2017, 12:34:55 AM »
Sorry to break the rules and mention value.   I found the serial by moving the pickup.  It was made in 1989.
