Author Topic: Weird buzz  (Read 2110 times)
Aaron1061
Weird buzz
« on: November 07, 2018, 01:44:12 PM »
i have a new 224ce k dlx and the es2 is finicky to get sounding right without the honky out of phase sound. i have it close, it sounds great playing softly but when i dig in it gets a little noticeable... dont really wanna buy a DI. i feel like it should sound great without external EQ. i mean it was 1500.
which leads to my next issue...
when i dig in, the G string reverberates like "wwuuaaaooong" idk how else to describe it. the action isnt low and the nut is cut right and the frets are level. it happens no matter what fret im playing on. only the g string.
it sounds as if its hitting one of the other frets im guessing but the action is NOT low. maybe my relief is too straight? please help.
LeftyBlues57
Re: Weird buzz
« Reply #1 on: November 07, 2018, 04:58:26 PM »
My 2 cents, hopefully it's NOT a sympathetic vibration. I had an Epi Casino hollowbody electric that had a really annoying sound, after an hour or two trying different things we discovered it was a tuning knob. Touch o' super glue solved it! That type of thing will drive you nuts.
MrYelnats
  • Stanley backwards...
Re: Weird buzz
« Reply #2 on: November 07, 2018, 05:52:06 PM »
I would try loosening the ES2 sensor hex screw behind and between the G and D string ever so slightly (1/16th turn at a time?)...this will reduce the gain and may cure the misbehaving G string  ;)
p.s. I'm assuming you are talking about the ES2 sound plugged in to an AMP...
« Last Edit: November 07, 2018, 05:54:06 PM by MrYelnats »
-2018 312ce Limited NAMM Lutz over Blackwood
-2016 614ce with Florentine Cutaway
-2012 414ce Ovangkol
-Martin 00015SM
-Martin CS 000, Red Spruce VTS top, Guatemalan back/sides.
GrainWave
Re: Weird buzz
« Reply #3 on: November 08, 2018, 02:17:15 AM »
Have you tried different strings?
Also try holding the other strings down while you get the G doing its thing to see if it is (as lefty suggested) sympathetic vibrations.
And finally is it sitting right on the saddle?
Black-n-Tan
Re: Weird buzz
« Reply #4 on: November 08, 2018, 05:50:15 AM »
Maybe similar issue to mine.
http://www.unofficialtaylorguitarforum.com/index.php?topic=9297.0
I simply removed wires from the inner body. No more buzz!
214-K-DLX
Re: Weird buzz
« Reply #5 on: November 08, 2018, 11:51:22 AM »
I had a buzz that was the control board for the ES buzzing on a D note, tough to find, easy fix that Taylor covered.
Re: Weird buzz
« Reply #6 on: November 08, 2018, 02:13:58 PM »
Years ago, I had a weird buzz that turned out to be a loose cable rattling against a brace.  I used a small 1" cube of foam, sliced open to allow the wire to slide into the cube, and attached it using double stick tape.  It held the wire nicely off the surfaces, preventing contact.
Intermittent buzzes and tones are the worst to troubleshoot.   :-[
