Well, good news and bad news with this endeavor. Actually, there's really not any
bad news, except to say that a 12-string Dreadnought (DN) is not on the
immediate horizon for me...
The long-and-short of it is that Joe at Empire Music got Taylor to dredge up a number of custom tonewood choices (seven, to be exact) from which I could choose. And Empire will be doing custom guitars using each of those wood sets, so those of you who are inclined to visit Empire should look for them to arrive in-store sometime around the first part of May (ostensibly in time for their May 15th Roadshow). Unfortunately,
none of the woods sets that would be the most appealing to me sonically were suitable for a DN body; apparently the available wood in most of these sets wasn't sized to accommodate the slightly wider upper portion of the Dreadnought body compared to the Grand Concert (GC), Grand Auditorium (GA), and Grand Symphony (GS). At least that's how it was explained to me... In any case, most of the wood sets were offered by Taylor as "GA/GS only."
There were a couple of nice sets of Walnut (one grafted, I think is the term); one set of figured Mahogany; a nice set of Ovangkol; a set of Amazon Rosewood (with a sliver of sap wood); a set of Myrtlewood; and a set of Tasmanian Tiger Myrtle. Ultimately, I don't know how Joe spec'ed out the ensuing custom guitars using most of those wood sets; but the latter set was compelling enough to me visually (see attached photo) to capture my interest. When Joe told me that Tasmanian Tiger Myrtle would be sonically similar to Koa and Maple, I really couldn't resist the urge to build a custom 12-string using it. But it will be a GS body...
Switching gears for a moment with this thought-exercise: Since starting this whole endeavor, I've learned that most of the guitars in Taylor's standard line-up (including DN'ts) are offered with an option to make them into a 12-string. I may ultimately pursue that route -- although I'm a bit unsure which of the current series would really be preferable to me: a 400-, 500-, or 600-Series Dreadnought...? Sadly, Taylor appears to have discontinued the K10/K20...
Sonically, I'm still a bit 'on the fence' about Ovangkol... I thought that, perhaps, I just needed to give it more time to 'grow' on me...? I've played it a number of times and it's fine; but I don't really seem any closer to considering it a 'go-to' tonewood for me, since I continue to gravitate toward tonewoods that possess a bit more inherent 'brightness...' And I
definitely prefer a gloss finish to the satin finish offered on (among others) the standard 400 Series...
The current 500-Series really seems to be geared toward an all-Mahogany body, although the Spruce-topped 500's are still available (and preferable to me, sonically). So, doing a 12-string 510ce (essentially a 550ce) would ostensibly mate well with the 510ce I have -- except that Taylor discontinued the Engelmann Spruce tops on the 510ce (they're now Sitka Spruce). And of the two Spruces, I prefer the Englemann...
A 12-string 610ce (effectively a 650ce) would seem to fit the bill. But after giving it more thought (and in light of the purported sonic properties of the custom GS-12 I'm now in the process of acquiring), I thought it better to shift the sonic 'focus' of a 12-string Dreadnought more toward the Mahogany end. So that would seem to eliminate Maple as a contender...
I was going to put Cocobolo back on the table, at least until such time as I can play it some more and determine that it's really not what I want sonically. It would seem to have the sonic range to fit what I'm considering, but all the extra 'bling' on the Presentation Series isn't appealing enough for me to consider a 'PS50ce.'
Similarly, Koa, Macassar Ebony, and Walnut remain in contention sonically. Of the three, Walnut might offer the best combination of properties ('off-menu' wood choice, providing the desired sonic range, and often visually striking); although so far, Walnut hasn't grabbed me sonically with anything but the GC and GA bodies. Wish I could find a Walnut-bodied DN to try out...
And that's not ruling out any other 'exotic' wood that Taylor might cough up either...
For the top, I may stick with European Spruce, which I do seem to like most of all. But Engelmann Spruce is also currently available through the BTO program (allowing me to do a 550ce-like guitar closer to my 510ce)... 'Sinker' Redwood has crossed my mind too, although I'm trying to imagine which back/side wood would pair best with that for a 12-string...?
But when the dust settles, all that mental wrangling seems to lead me back to a custom DN... So, stay tuned, sports fans! It'll probably happen someday...!
