« Reply #28 on: July 23, 2017, 12:05:19 PM »
... I see there are pickguard options... standard brown, clear, or none? Which would be most advisable? I'd prefer not, but is it ok to have no pick guard...?? 🙂
depends on how heavy your attack is. i'm a light to medium strummer and don't have any nicks...except a couple on my cedar topped guitar. cedar is softer wood - but they are tiny
the lutz on the 714ce isn't soft so you should be ok...
More to the point, Taylor's finish (which is covering the wood) is pretty durable. I'm sure repeated scuffing with a pick would eventually create scratches, in even Taylor's finish. But I wouldn't worry so much about getting marks from occasionally swiping a pick across it. The caveat here is the thinner finishes on Taylor's newer models is more susceptible to getting marks. I don't rightly recall if the new 700's have the thinner finish like the current 800's, though...
In the end you're probably fine going without the pick guard (or a clear one installed); or having it provided loose in the case as "zeebow" suggested. I'm a moderate strummer and don't have any problems with marks on the tops of my Taylors -- even the ones without pick guards. So I guess I'm a testimonial for Bob's response to the question of pick guard or no pick guard.
T5: C1, C5-12, S (Aztec Gold)
