I never abused it the lid just came un hinged on both ends so I bolted two new ones on. The rivets came thru from the inside out and the little hinge pins ended up breaking. The case is solid no problems there just weak hardware.
Quote from: oogaboogachiefwalkingdeer on January 01, 2014, 05:49:13 PMI never abused it the lid just came un hinged on both ends so I bolted two new ones on. The rivets came thru from the inside out and the little hinge pins ended up breaking. The case is solid no problems there just weak hardware.Have you let Taylor know?
.... I did learn from that day forward every time I put a guitar down it goes in a case with at least two latchs hooked...
Quote from: oogaboogachiefwalkingdeer on January 01, 2014, 06:57:22 PM.... I did learn from that day forward every time I put a guitar down it goes in a case with at least two latchs hooked...two latches out of five i doubt the issue was a faulty hinge ...
in general, clip on tuners & straps should be removed from the guitar before it is cased -the tuner may leave a mark on the headstock from the padded clamp material & it ispossible that a strap may react with the finish of certain guitars if draped over the topthe chances of unnecessary scratches or headstock marks/nicksmay be reduced by removing the tuner & strap when not in use
Quote from: stepchildusmc on December 30, 2013, 08:07:50 PMi love the tight fit of my taylors. i know they aren't gonna shake around in there.Me, too. Like someone above, I stick the lower bout in, then push the guitar into the case by the bridge to keep from getting fingerprints on the top. Love the snugness. It's like closing the door on a Rolls Royce.
