I was wondering if someone knows about the bracing of 914ce model, year 2000. What is it called? My second question... what's the close date Taylor started making NT necks on high end models?
thanx
As I recall, Taylor introduced the NT neck in 1999, Standard II (forward shifted with relief rout) bracing in 2006 and CV bracing around 2008.
The tonal difference between Standard II bracing and the bracing that preceded it, which was also scalloped X-bracing positioned slightly aft of where Standard II is positioned, was more subtle than between Standard II and CV bracing.
I would expect that a 2000 914 would have the NT neck. NT necks made between 1999 and 2006 are easily identified by the finger joint that joins the headstock to the neck. In 2007, the finger joint was replaced by the more esthetic scarf joint.
