So, 30 days have gone by and it is time for an update.
1) returned the Weeping Willow Stratocaster (Let's just say it was not up to par)
2) bought a 2012 American Standard Stratocaster instead.
3) also bought the Fender Acoustasonic 100 watt Amp
(Sadly, the Blackstar 5 Watt tube amp is much louder).
4) bought a DD-20 BOSS twin pedal delay.
5) and the BOSS CH-1 Chorus.
6) Also the Ibanez Tube Screamer TS-9 Overdrive Pedal
7) and the Dunlop JH-F1 Jimi Hendrix Fuzz Face Pedal.
also the much needed Mike stand, Mike and accessories to complete the set.
So, anyone deciding on the Fender Acoustasonic realize, it is very weak no matter what you play through it and no matter what your settings are.
It sounds great, but it sounds very weak..
There is no way this should rate as 100 watts
No way it should rate as 50 watts per channel
I have 10 watt (CHEAP) amps that are louder..
But, the Fender Acoustasonic does sound great and it has a lot of features.
It will not entertain nor will it disturb your neighbors.
Perhaps if you plugged in at their front door and cranked it up till the amp began to distort, you might get their attention.
In the Music store it sounds okay (Low Volume), but I am shaking my head on this one.
The only way to get any sound out of it at all is to turn it to pure amp.
Anyways, just saying.. Make sure you crank it up before you buy it..
