... I have a Princeton Reverb, a SR Technologies Jam 150 Plus Acoustic Amp, I also use a Boss DR-880 that I love. I also have a Boss Eband JS-10 on the way which has the same processor as the Boss GT-100. I'm also thinking about going with an Eleven Rack and running it into a couple high end studio Monitors. I want the Eleven Rack and Studio Monitors to work. It would be the easiest solution for hauling back and forth to Florida for the winter. I'm strictly a home player. So, what do ya think?
Yeah, I think you're perfectly fine with the Fender PR ...which if I read you right will serve as the "core electric tone" for your rig. The GT100 is what you make of it: you can use the models, or bypass the models and use it for the effects (like an all-in-one programmable stompbox). The former diminishes the affect (or should I say "benefit," but that's my bias toward tubes
) of your using a tube amp, whereas the latter retains the PR's voicing as your tonal
foundation, on which you are simply layering effects on top. I personally prefer the latter, but that's entirely up to you and your ears/tastes. Sorry if I'm telling you the obvious ...I'm certain you know your gear!
Never used a JS10, and the DR880 is a staple, so sure, good to go.
Eleven rack is pretty dang sweet ...and you say you don't play out?!!
And the Jam150 is more "PA" like ...which is what you need. Colorless flat EQ, and the ability to tone shape, is the best way to get the most out of a Taylor ES system which is, in essence, what the T5 is offering you. So yessir, IMHO you have no shortage of nice gear there, and getting good electric tone from the PR and fx side is easy, while switching to your acoustic rig is literally a click away (if playing live with a A/B/Y switcher box); or just going through the acoustic rig will yield you nice acoustic-ish tone. If you were on a Rainsong and find playing the T5 physically your solution, then yes, I think you'll find the acoustic tone to your liking. Adn if you don't, well then tear up that bill I sent you and consider this free advice
