Author Topic: Amp Input: High or Low?  (Read 4296 times)
  • Northern California
« on: March 29, 2012, 06:58:30 PM »
My amp (Phil Jones AG150 Cub II) has two inputs, and each is separately switchable from low to high gain.
Which input switch position on the amp should I use with my 2012 ES system on my 812ce?  If I use the wrong position in the amp, will my Taylor blow up?  Or will my amp blow up?  Or will I disappear in a cloud of smoke?
The amp's manual says:  "High: Higher sensitivity, high impedence input. Low:  Lower sensitivity input setting for guitars with onboard electronics."  While that might seem like the obvious answer, I'm not taking any chances that I might blow something up!
This is a great amp, by the way.
randyc
Re: Amp Input: High or Low?
« Reply #1 on: March 29, 2012, 07:13:25 PM »
The obvious answer is the correct one, as you surmised.  Using the high impedance input will not damage guitar or amplifier but may cause output distortion when a low impedance, high output source (your guitar) is used.
« Reply #2 on: March 29, 2012, 07:24:06 PM »
No, your Taylor or amp will not blow up, but if you plug into the wrong input the fabric of the space-time continuum will be torn and we'll all be sucked into a worm hole where we'll have to listen to William Shatner recordings on continuous auto repeat.   Not sure about the cloud of smoke part.
Be Careful !!!!!
« Reply #3 on: March 29, 2012, 07:29:09 PM »
Be Careful !!!!!
 Oh no!!   I might have to listen to continuous Polka or endless repeats of "When the Saints Go Marching In"!  I'm unplugging everything!!!!
« Reply #4 on: March 29, 2012, 09:08:38 PM »
Could be worse: you could be stuck listening to "It's a small world" ...the ride got stuck and we were all a very captive audience, but therapy is helping.
Hey Navy,
Nothing bad will happen.  All that means is each input setting is "gained" differently: use the one that sounds better/cleaner.  BTW, look at your other posting as I responded there :)
« Reply #5 on: March 29, 2012, 09:19:42 PM »
Be Careful !!!!!
Oh, man.....I HATE it when that happens..... ;D
« Reply #6 on: April 01, 2012, 01:41:57 AM »
looking at the Cub II & viewing the manual, i found the input
gain switch description/usage to be a little 'cryptic' (to me)
high (sensitivity/impedence) - passive or magnetic pickups
high impedence is a hi-Z, unbalanced signal, which can come from a 1/4" tip/sleeve output
not all magnetic pickups are passive, as LR Baggs & Fishman, to name 2,
make low-impedence magnetic pickups (M1 active & rare earth humbucking)
with balanced 1/4" TRS out, which allows a second source to be added
low (sensitivity/impedence) -
onboard electronics (active, balanced out 1/4" TRS or XLR) &
a quality 1/4" TRS to 1/4" TRS instrument cable will usually
have the same effect as a 1/4" TRS to XLR cable with the ES
XLR inputs are usually designed for line-level devices (mics)
which mean the amp would 'boost' the input signal, assuming it
does not have phantom power, which may  be problematic when
using a instrument with an active pick up (a 'hot' input signal)
many dual source pick ups have a balanced output, such as the LR Baggs Anthem &
Fishman stereo blender, but not all guitars with onboard electronics (EQ) are
active & if the guitar has an unbalanced out (1/4" tip sleeve), using a
1/4" TRS to 1/4" TRS cable may result in no signal going to the amplifier
the Shadow P7 is an active (9V) single source UST
with onboard pre-amp & a hi-z (unbalanced) 1/4" out
if the signal from the ES is too 'hot' using the balanced cable &
lo-Z input (if it requires too much 'pad' or gain cut at the guitar &
or the amp), i would use the hi-Z unbalanced input or flip the switch
ymmv
