Dear musicians
I am pretty happy I came across this forum. After my registration and presentation, I have received a very warm and friendly welcome.
Thank you :-)
As written in my introduction post, some months ago I bought a gently used 2009 Taylor 312CE equipped with Expression System.
This is my first "good level" guitar (after some cheaper instruments manufactured by Aria, Ibanez and Seagull), and I was quite excited when I found it in perfect conditions at a very reasonable price; so I decided to buy it.
The overall quality is really good and the neck is very comfortable.
My enthusiasm and happiness were somehow downsized when I got home and I replaced the wornout strings with a new set , and eventually plugged the Taylor to my amplifier.
1. the guitar itself sounds quite good but lacks some sustain and bass frequencies; when I strum or pick the E string or the A string (of a fresh strings set), the sustain is short and not as loud as I expected; this is acceptable in the strummed parts of a song, but it becomes frustrating when it come to fingerpicking: the volume is low even using a thumbpick. In other words, and pardon me for my English, I suspect that this guitar doesn't have a strong resonance. I tried many different sets, gauges and brands of strings but the sound is not brilliant, shaped, loud.
2. the worst surprised arrived when I first plugged the 312CE to my Kustom Sienna acoustic guitar amplifier which, that to be said, is far from being a professional amplifier but is anyway a honest transistor amplifier which served me well with my previous guitars. The problem is that the output level is ridiculous, close to zero, even with the volume knobs set to 10. I found this
http://www.unofficialtaylorguitarforum.com/index.php?topic=4568.msg49447#msg49447thread where a veteran member explains that the Expression System works better when connected with a balanced cable to a balanced input (which my Kustom doesn't have), but I am a bit upset anyway: how can it be possible that a
XXXX euros guitar plugged to a dedicated amplifier has no volume? Things get better when I plug the guitar with a TRS cable to the mixer's XLR input and the amplifier in the mixer's send/return channel: the mixer preamplifies the guitar output so the output volume is louder, which helps me a lot when I play live. But I am still unsatisfied because it looks like I will always need an extra preamplifier system in addition to the onboard preamplifier.
So, these are my considerations and impressions about my first Taylor acoustic guitar. Sorry for the long post and the grammar mistakes.
I am pretty sure that you experienced musicians will be able to help me increase and improve the sound and the tune of this guitar. Probably, there's something wrong with my rig, gear and connections .
Your suggestions and comments will be appreciated. Thank you
w
