Thanks Guys for the response. I will take it to get it checked this Friday. In my thread I stated that it was hard to fret. What I guess really is the problem is that the strings are very hard to press down and hold for very long. Maybe a nut height problem. Seems that the strings on the Taylor are a lot harder to press down than the strings on the other guitars. Maybe it just that I am not use to a high $ guitar. Probably just my left hand instead of the Taylor. LOL
Jimmy
Hi Jimmy,
Well you've already heard the answer: setup setup setup
Keep in mind there is not one "setup spec" that is correct ...not even "factory spec" is "correct" any more than one kind of car suits all purposes, let alone tastes. FWIW, Taylor puts out one of the best-spec'd setups on a factory guitar, IMHO ...but
lots happens between the factory, the store wall, and your home. Then there's time and climate that lends its share of whoopteedoos on what was once a -well-playing guitar. Yet that said, a truly proper setup is the result of a
skilled tech who
understands the actual person playing the guit.
What that means is there are a bunch of hacks who say they can do a setup as it is a relatively easy job to do, and even easier to screw up! Furthermore, a truly good tech will ask you what you want, how you play, even what style of music ...all to meet
your personal requirements for a truly proper setup that works for your style and tastes. IMHO, there is simply no shortcut around asking around for a good tech in your area who enjoys a great reputation. Hope that gives you a bit o' food for thought
