Author Topic: Hi all Newbie here  (Read 952 times)
msinks
    • Pampa's Tribute to Woody Guthrie
Hi all Newbie here
« on: June 27, 2013, 10:27:42 PM »
Just got a 320e Mahogany! The expression system is so sensitive, it's kinda kickin my butt. The guitar is a cannon in mid and low range acousticly. Plugged in I'm having to turn bass and treb all the way down. Any thoughts? I'm running through a SWR amp.
Re: Hi all Newbie here
« Reply #1 on: June 28, 2013, 06:41:33 AM »
Welcome Mike. We are glad you joined us. Congrats on your new 320e. I can't answer your questions....someone who can will jump in. Have fun here.
sitedrifter
« Reply #2 on: June 28, 2013, 06:49:47 AM »
Hi msinks!
I just read about the ES system from a document a fellow member pointed to me. There are 2 dip switches that allows you to turn off each of the body sensors to allow for different sounds. This maybe your answer to getting the bass just right for your application.
Check out this PDF
http://www.taylorguitars.com/global/pdfs/10_UnderstandingES.pdf
Mark
  • 2013 Taylor 416ce-LTD (Sitka/Granadillo)
  • 2012 Gretsch CVT
  • 2012 Yamaha A1M
« Reply #3 on: June 28, 2013, 11:43:07 PM »
 Hi msinks.  :) Welcome to the UTGF. Congrats on the new 320e. The link sitedrifter posted should help you narrow down the EQ problem. Good luck.
2014 Taylor 524ce
2013 Martin 000-28EC Sunburst
2011 Taylor 314ce
2008 Taylor SB-1 Classic
stepchildusmc
« Reply #4 on: June 29, 2013, 07:40:18 AM »
welcome in msinks ! this is the most knowledgable Taylor forum on the planet. you'll learn quite a bit here and hopefully have some fun too!
Steppy
2008 NAMM Hot Rod(GA)
2013 spring ltd. 616 ce
2013 616 ce(honeyburst)
2011 Adamas 2080Sr
2014 324
2014 GS mini Hog
2013 GS mini Spruce
2014 GS mini Engelmann (HV)
« Reply #5 on: July 03, 2013, 01:00:21 AM »
Great to have you here!  ;D
