On my Martin M-36 I have been getting a strange tone on my G string, it is a horrid twang. I have put a capo on and it still makes that twang. So I loosened the strings and pulled them out of the bridge, and I found that the saddle has a notch in it where the G string rests. Would you say that the notch in the saddle is the cause of the problem?
If the damaged saddle is the cause what can I do? It is a bone saddle and I thinking if I sand it down it will alter the tone it should have. Since I wanted to get some positive results for my efforts I rubbed the sharp edges off a bit. I put the string back on and now the problem sound is not a intense as it had been, but not completely removed. So, should I sand it?
