Naaaaah, that's only because the grain just looks like an X pattern because of the mirrored halves.
It forms the shape of a butterfly but on each 1/2 the main dark line is more or less bending outward at the top. Down at the bottom the line is more straight, so initially I mirrored two pictures and joined those at the bottom because the line is straight. At the neck the more angled line was matched with yet another mirrored picture so two neck joints meet in the centre.
I reasoned that the more angled line may not truely follow the tree's circumference, whereas the other one was probably a little too straight. This was compensated for by a little more rotation on the curved side of the grain.
However as Gutch noticed, I forgot about the quarter sawing. The more white sapwood is on the outside of the tree but it's not running from left to right as in my picture. Quartersawn means it runs from lower down the tree to higher up on the outside of the tree and then to the centre, the tops should be sitting upright in a starshaped pattern.
I should've known that but wasn't thinking properly at the moment I had to idea to calculate the tree's circumference.
If I had been aware of it I probably wouldn't even have started this can of worms, because it's nearly impossible to set the pictures on their sides and get an idea about the tree's circumference. That's because the grain runs to the centre of the tree and all you can say is that the top is just a thickness taken out of a circumference which can be any size and this thickness is only about 0.25 of an inch of the entire circumference.
Perhaps it's easier with Mahogany, it sure doesn't work for Koa.
Case closed.
Don't worry about not being a luthier Cindy, neither am I,
BTW the flames darker and brighter parts are perpendicular to the grain, it's the dark band and the white sapwood's direction which mark the running of the grain, those are in line with the yearrings, I think?
Ludwig
