Lessons, Recordings, How Tos, Repair, Accessories
814ce with Volume Pedal
Pages: [
Topic: 814ce with Volume Pedal (Read 1147 times)
sifender56
New Member
on:
August 10, 2012, 03:45:58 AM »
Hi guys
If I use a volume pedal with my 814ce can I still use a TRS-XLR cable on the out of the pedal?
Thanks
Giraku
Sr. Member
I play exclusively fingerstyle.
Re: 814ce with Volume Pedal
Reply #1 on:
August 10, 2012, 07:47:40 AM »
If your pedal accepts XLR in and out, yes.
‘18 Taylor K14ce Builder’s Edition (Koa / Torrefied Sitka Spruce)
'16 Taylor 514ce LTD (Granadillo / Cedar)
'16 Taylor K22e LTD (All Koa)
'15 Martin D41 Purple Martin #29 of 50 (Cocobolo / Adirondack Spruce)
Sound Clips are here.
sifender56
New Member
Reply #2 on:
August 11, 2012, 04:12:04 AM »
So could I not just use a normal jack- jack from guitar to pedal then an trs-XLR on the out of the pedal??
Giraku
Sr. Member
Reply #3 on:
August 11, 2012, 09:11:54 AM »
No. To make it work the following conditions are required:
1. The pedal accepts XLR signal in/out.
2. Use TRS-TRS cable between the pedal and the guitar.
3. Use TRS-XLR cable from the pedal to whatever equipment that accepts XLR signal.
Pages: [
