Author Topic: The "best" acoustic DI  (Read 9958 times)
joelvan77
« on: January 11, 2013, 04:22:55 PM »
What is your favorite way to plug your guitar in live?
2013 Taylor 814C
1981 Fender Stratocaster
2008 Fender Lite Ash Stratocaster
1999 Gibson Les Paul
2004 Fender Telecaster
Custom made Telecaster
ericjungemann
Re: The "best" acoustic DI
« Reply #1 on: January 11, 2013, 07:57:29 PM »
Direct to a Loudbox Mini (656ce).
Eric
Eric Jungemann
GS Mini E Koa Plus
150e
texasdw
« Reply #2 on: January 11, 2013, 10:17:10 PM »
Depends on the guitar.  But for a Taylor steel string I like the Taylor K4.  It is however darn expensive.
leeasam
« Reply #3 on: January 12, 2013, 12:48:02 PM »
with the ES system I use a 1/4 TRS to XLR straight to snake and then to board. No need IMO for anything else.
2010 816CE Taylor
2012 PRS P22 Black Gold wrap around
2012 Taylor GS mini
« Reply #4 on: January 12, 2013, 06:57:23 PM »
Because a Taylor has a balanced, low-impedance output, a DI is superfluous. For other guitars, I would want a Radial JDI.
Some people when using the term, DI, don't mean a direct input box (a device that converts an unbalanced, high-impedance signal to a balanced low-impedance not) but rather a preamplifier with an output that is compatible with balanced, low-impedance equipment.
Steely Glen
  • UTGF Member #2
« Reply #5 on: January 12, 2013, 11:55:33 PM »
While more than a DI (which the ES doesn't need), the Taylor K4 is an impressive piece of kit.  I have one that I use with my ES-equipped Taylors and it sparkles.
Taylor Guitars & Gear:
2010 Taylor 816ce
2011 Taylor 714ce
2005 Taylor 555ce
Taylor K4 Preamp
« Reply #6 on: January 13, 2013, 11:16:57 PM »
I use an 1/4 TRS to XLR to an Audix T50k Impedance Transformer into my amp (either a VOX AGA 70 or Fishman Loudbox Mini).
briguysm
  • Yeah, I "play" guitar...
    • The Attic STL
« Reply #7 on: January 16, 2013, 06:02:31 PM »
L. R. Baggs Venue.
And I'll totally agree with others who say it depends on the guitar. I love the Venue and how my guitar sounds through it.
« Last Edit: January 17, 2013, 12:23:27 PM by briguysm »
2012 Taylor Custom GA BTO - Sinker/Macassar
1998 Taylor W-10
2018 Duesenberg Starplayer TV sparkle blue
MrTing
« Reply #8 on: May 25, 2013, 07:24:12 PM »
I use a Baggs Para DI and love it.   However, the Radial active DI is amazing.   I played through a couple and it was noticeable how much headroom they have.    Adam Rafferty went through everything and tours the world with a J48.
jivauk
  • Sadly Jimmy lost his fight with cancer 3 Nov 2015
    • singer/songwriter duo, a gentle blend of acoustic instruments and vocal harmony
« Reply #9 on: May 25, 2013, 08:20:14 PM »
We plug our Taylor guitars and Kala tenor ukes and Val's Kala U-Bass ino a pair of Bose T1 Tonematch preamp/mixers.
From there, out to either our Bose L1 model 2 or AER Alpha Plus or the venue house system.
Val
www.jiva.co.uk
Guitars: Taylor, Yamaha, Eko
Ukuleles: Kala
Sound System: Bose, AER
soma89
« Reply #10 on: May 29, 2013, 11:04:06 PM »
I really like the tube Di boxes....the one i have in mind is a long red box...and its gone from my mind.
soma89
« Reply #11 on: May 30, 2013, 08:32:21 AM »
ok...it`s called the A-Designs Audio REDDI.
And for much cheaper..the Radial JDI Mk3
uberschall
« Reply #12 on: July 03, 2013, 07:26:19 PM »
I liked all the features of the Baggs Venue, but found the tuner very disappointing. I also wish they'd sell it with the foam pads separate, so it was easier to velcro it. The Para DI was also great, especially the notch filters. I like DI boxes which have extra functions like loops and boosts.
MikeB
« Reply #13 on: August 15, 2013, 04:26:29 PM »
I just came across this thread.  I didn't realize that the Taylor has a balanced output.  I've been plugging in using a standard TS -TS cable.  Will I get a better sound using a TRS-XLR cable when plugging into a PA mixer/head?  I haven't had any noise issues doing it the way I have been, including plugging into my Tascam US-800 audio interface
« Reply #14 on: August 16, 2013, 08:21:42 AM »
...Will I get a better sound using a TRS-XLR cable when plugging into a PA mixer/head? ...
Maybe, maybe not. You will be sending a stronger signal to the PA (3 dB louder) which means less noise because the gain doesn’t need to be turned up as much to achieve the same volume level and because the added shielding better resists induction noise.
